Question about Carrier Heating & Cooling
Carrier unit won't shut off - Carrier Heating & Cooling
  • Brad Brown Dec 12, 2016
    Hi Russie West, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Model and is it the outside unit or the inside one?
  • Russie West Dec 12, 2016
    fa4bnf048 heat inside blower n heating elements I took thermostat off n unhooked wires n individual switches one at a time I think it's a switch but had brain lock standing there in front of it lol! I don't have wiring diagram having to tracers wire
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
Carrier 38 leo 30320 ac unit....when the compressor shuts off the fan keeps running. a rap on the control panel shuts it off. I when changed the contactor the inside unit stopped working so I put the
Hello, if the indoor blower runs nonstop a relay in the intergrated control board faulty and the whole board must be replaced, you can get tap the board to stop the blower but eventually the board will need to be replaced. If the contactor is clicking that means it is receivingpower from the indoor unit
Jun 16, 2012 | Carrier Heating & Cooling
Check the t-stat to make sure that the "fan" switch is st to auto. If not the fan is in the "on" position and is always on. Otherwise, It sounds like your "Central Air" is a packaged unit(Furnace and air all one unit outside the home) and the fan relay inside the unit is stuck. This need to be replaced. It is the rectangular unit with the leads from the fan motor attached to it.
Jul 29, 2011 | Heating & Cooling
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
I have a Carrier 38CKB048 and it runs without shutting off.
99.9% probability that your contactor is stuck/sticking. Replace the contactor.
Apr 27, 2010 | Carrier 38CKC024 Air Conditioner
Outdoor carrier cond. comes on but the indoor
Bearings in fan motro bad or bad capacitor. Depending on size of unit should be 5uf 370 capacitor. Replace cap. ans try to start unit.
Jun 10, 2009 | Heating & Cooling
My Carrier AC fan will not turn, only blows out warm air.
Breaker has popped either at breaker box or at the safety shut off switch. Fuses are blown or the sending unit has popped.
Apr 30, 2009 | Carrier BCA101R Air Conditioner
Carrier casement unit shuts off automatically
E4 indicates your unit is in need of service.
May 07, 2008 | Carrier XHC101D Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
