Question about Fish
The web in my tank is a fish tank, not a car.
My betta fish is not eating. I placed a holiday disk in his tank for food while we were away this weekend.. Just got home and the water was extremely cloudy
I hope you did a big water change right away. The very first thing to do, any time there is a problem with water for fish, is to change at least half of it right away. If you have dip strip tests, test some of the water you change to find out if any readings are too high, but do the change first. If you don't have tests, you should consider getting some, they are the only way to tell if the water has too much ammonia, nitrite or nitrate for fish safety.
Cloudy water often means a bacterial bloom has happened, which isn't always dangerous to the fish. But sometimes they can be the result of a rise in ammonia. All fish produce ammonia as part of their respiration and all organic waste, which is broken down by bacterial action, also produces some ammonia.
For the future, It is MUCH safer to simply not feed your fish if you are going away unless perhaps you are trying to raise valuable fry. But most tanks of fry would also probably survive if their tank is provided with large masses of live mosses and floating plants. These provide minute food resources, infusoria, bacteria, algaes, which fish can pick from the plants. Plants, of course, need enough light so they don't die off.
For sure, unfed fish will get hungry, but healthy fish will not starve to ***** in a short time. Most fish can do fine for a week and I leave mine for two and three weeks if I must and so far, nobody has died. During an emergency, my fish survived for over a month without any attention at all, far from ideal but it could not be avoided. Those fish were living in a heavily planted tank and the plants provided food resources. It also contained shrimp and live scuds the fish could eat, though they didn't eat them all.
Even an unplanted tank, if not over-stocked, should be ok, unfed, for 5-7 days, so long as the fish are all healthy and similarly sized. Tiny fish are likely to be eaten if their tank mates are big enough and hungry. If possible, put the tank lights on a timer so the day/night cycle continues while you are away. Full-time darkness won't kill them but is probably not much fun for them, either.
Fasting fish also helps avoid potentially serious water quality problems that uneaten food and fish wastes may cause in a surprisingly short time. Many keepers fast their fish routinely, one or two days a week, which is thought to mimic the erratic availability of food in the wild.
Having living plants in the tank is very useful; they use up ammonia and nitrates and provide interest, shelter and resting places for the fish. Water changes serve to keep all toxin levels at safe levels. Nitrate should not test over 50 ppm at most, 10-20 is best. Ammonia & nitrite should always be ZERO. If any levels are over these, big water changes are the only remedy.
Any fish's tank, including that of a Betta fish, should have a filter of some kind. If it does, changing 50% of the water weekly is what I have found works out for the best. Filters convert ammonia and nitrite to nitrate, the least toxic
Sadly, it's still popular to keep Betta fish in bowls without filters. It's a long way from ideal, but if water changes are done diligently, the fish may be ok, though it often ends up chopping a year or more from their life span. Without a filter, 50% of the water should be changed THREE times each week. That's a lot more changes than most advisory sites will say, but fresh, clean water is the single best friend any fish will ever have living in captivity. Make sure the fresh water's temp' is within a degree or two of the tank's temp' when you change it. Use a siphon or turkey baster to suck up fish waste from the bottom at least every other week, if not more often. Don't remove the fish when you do these maintenance tasks because that can be a lot more stressful than leaving it in.
Never feed Betta fish any more food than they can consume within a maximum of about ten minutes. Many of them tend to be very slow or picky eaters, so they need more time than most other fish species. Remove any uneaten food after a half an hour.
Mar 20, 2017 | Fish
Tip
Using a pH meter to care for your fish
pH values are the acidity of a body of water. Neutral water has a value of 7.0 meaning that it has equal amounts of hydrogen ions and hydroxide ions. When more hydrogen ions are added the water then the number goes down and the water becomes more acidic, or if the amount of hydroxide ions goes up then the water becomes more alkaline.
pH levels in your fish tank can prove to be fatal if they aren't monitored properly. While there is no secret formula for the perfect pH level for all fish it is best to keep all the fish from the same bodies of water together. Salt water fish shouldn't be put in a tank with freshwater fish because they need different pH levels.
Throughout the day the pH level of your fish tank will change although these slight changes shouldn't be too harmful on your fish sudden changes will prove to be fatal. When you are moving fish from one tank to another you want to make sure that the two waters have the same pH levels. When you want to buy a new fish check the pH level of your fish tank and then the pH level of the water at the pet shop to make sure that the levels are not too different.
You should be checking the pH levels of your fish tank at least once a month, but more often is always better. When you take the pH level you should write it down in a log book. You should try to take the pH level at the same time every time you take a reading because at different times of the day the levels would be different. Try to keep yourself from going crazy, if the pH level is a few decimals off of perfect your fish will be okay. If the level is fairly regular you shouldn't have to do anything unless your fish show signs of distress.
on Feb 02, 2014 | Measuring Tools & Sensors
Remove gas tank from Mitsubishi Outlander 2004
on something like this your better off replacing the tank with new one ,id rather not fix something this new . don't forget to drain gas b4 you start and don't forget to purchase new fill seal gasket and level sensor (you'll never get old one out to reuse it ) new tanks don't come with them !! and don t use electric pump to drain gas out !!!(boom!!) me I have an old siphon fish tank pump I use for this purpose !! and I don't use it for fish !!
Oct 03, 2016 | 2004 Mitsubishi Outlander LS 4WD
Fish
Hey Manni, Fish can be tricky critters to diagnose at the best of times- and online is harder by far because you cant really watch the fish.
Can you tell me a few details so I have a better idea of the situation? What kind of fish is it, how long has it been sitting at the bottom of the tank and are there other fish in the tank with it?
The first things I would check are the Ph. levels, the algae level, temperature and if you have a filter/aerator that it isn't clogged and is letting sufficient oxygen into the water. If all these things are ok, we need to take a closer look at the fish itself.
Jun 16, 2013 | Pets - Others
Bith of gold fish
Goldfish are egg layers. Unless you have Comets, (commonly referred to as "feeder fish", or "carnival goldfish"), or Koi, they are both in the Carp family and are live-bearing. Meaning once the female gives birth, you must seperate the "fry" a.k.a. baby fish from all other fish in the tank or they'll become a snack. Pet stores sell breeder boxes to float in your tank that the babies stay in until they're big enough that they won't get eaten, there's also special food for babies once they're born or hatched from eggs.
Apr 09, 2013 | Fish
Replace fuel pump in a 2003 axiom
r u sure its the fuel pump?is it the anti theft??pump is in tank
Sep 26, 2012 | 2003 Isuzu Axiom
Can I make my own fish food dispenser for my tank? I really don't want to spend more money on my fish.
You can try making your own. But make sure you try it out for a few days before you go away just in case there is a problem.
Aug 26, 2012 | Archos Fish
My fish tank air pump broke and I think my fish aren't getting enought oxygen because of it. Should I buy a new one or can it be fixed?
Technically, it can befixed but if it happens once, it will likely happen again. You should buy a new one as they aregenerally pretty cheap. In the meantime,fill a large bowl with water and place the fish there. This will allow them to get some fresh oxygen. While the fish are in the temporary container,get rid of all of the water in the tank. Then, refill again with new, oxygenated water. I wouldn't leave them in this environment formore than a day before you purchase a new air pump.
May 13, 2012 | Fish
Fish Logo
2,150 people viewed this question
Top Fish Experts
Richard Lindsey ...
Tom Chichester
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
