Im having problem with my server. Error the file replication is having trouble enabling form server 1 to server 2 for C:\windows\sysvol\domain using the DNS name. FRS will keep retrying.
My second domain cannot pickup the primary domain.
  • Brett Duxbury
    Brett Duxbury Dec 12, 2016
    Hi Anonymous, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    are the IP addresses on each server different and in the same subnet mask . Are you using sub netting or a full subnet mask eg 255.255.255.0 or are the numbers less than 255 and not zero ?
    what sort of router is it cisco ?
    Are V-lans involved or restrictions on server connections ?
  • 7 Answers
SOURCE: First timer installing a Server network
The total problem is vth ur DNS server only. If u does'nt configure the DNS server properly then these problems arises. Check the DNS server IP as well as Pref DNS server are similar in the DNS server and even in  the client side make sure that the IP must be diff and Pref DNS must be assigned of the DNS server.
Posted on Oct 18, 2007
gilgamer01
  • 135 Answers
SOURCE: DNS error (80410411) cannot find server
If you are using a public router (meaning you're using just a connection from somebody else's router) prolly, you're DNS have been blocked...have you tried connecting to other sources other than the one you can't use? If you have a connection and you don't own your own wireless router, try borrowing one from someone you know first then try if it works...then that's the time you should ask for your own wireless router...
Posted on Jul 29, 2008
  • 74 Answers
SOURCE: The File Replication Service has detected that the replica set "DOMAIN SYSTEM VOLUME (SYSVOL SHARE)" is in JRNL_WRAP_ERROR.
Make sure and keep copies of all the folders and files.
Take these actions to resolve your problem:
On all Active Directory registered domain controllers:
1. Stop NETLOGON Service
2. Stop File Replication Service (NTFRS)
On the PDC Emulator:
1. Rename all files in the %systemroot%\ntfrs folder and subfolders (change their extension to .old).
2. Give an unlisted account full control of the directory %systemroot%\SYSVOL folder and reset permissions on all child objects.
3. Change the registry key:
HKLM\System\CurrentControlSet\Services\ntfrs\paramaters\Backup/Restore\Process at Startup\BurFlags (REG_DWORD) = D4 (The default on this is 0)
4. Start the NETLOGON Service
5. Start the NTFRS Service
On all non-PDC emulators:
1. Change the registry key:
HKLM\System\CurrentControlSet\Services\ntfrs\paramaters\Backup/Restore\Process at Startup\BurFlags (REG_DWORD) = D2
2. Start the NETLOGON Service
3. Start the File Replication Service (NTFRS)
At this point, the system in question should have recreated the SYSVOL share and the NETLOGON share. Check this by running 'net share' from a command prompt. You should also see the Group Policy Objects listed in the SYSVOL directory as:
%systemroot%\SYSVOL\domain_name\Policies\{31B2F340-016D-11D2-945F-00C04FB984F9}
%systemroot%\SYSVOL\domain_name\Policies\{6AC1786C-016F-11D2-945F-00C04FB984F9}
There may be more directories listed here, but these are the Default Domain Policy and the Default Domain Controllers Policy that are installed by default when the Active Directory is created. If these are being replicated, then file replication is functioning.
If you cannot find these directories, then you may have to manually recreate them. Here is a list of the proper directory structure of the %systemroot%\SYSVOL folder:
\SYSVOL
________\domain
________________\DO_NOT_REMOVE_NtFrs_PreInstall_Directory
________________\Policies
________________\Scripts
________\scripts
________\staging
________\staging areas
________________\domain_name
________\sysvol (shared as SYSVOL)
________________________\DO_NOT_REMOVE_NtFrs_PreInstall_Directory
________________________\Policies
________________________\Scripts (shared as NETLOGON)
If you have to manually recreate the directories, restart the File Replication Service (NTFRS) on all domain controllers to re-enable replication. This should get the file replication functioning normally
Posted on Nov 25, 2008
  • 13 Answers
SOURCE: netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Posted on Feb 06, 2009
  • 4 Answers
SOURCE: Can't configure router for Domain name and DNS
dns= domain naming service or something alike...
you don't have normally to anything to your router other than allowing incoming traffic to port 80...once you do that, you should be all set..frrom your computer at home if you type your domain name, your pc actually goes to the internet clowd and accesses you new domain name based on the info gathered by dyndns...then comes back to the ip that your ISP assigned you and hits your webserver...
A couple things to consider;
keep an eye on the ip assigned to you by the ISP..if it changes by DHCP your webserver won't be seen by the outside..
on your side of the home network, assign a static ip address, don't use dhcp as well to avoid the same problem on the pc that you have the webserver. your router should allow you to allow traffic on port 80 to your webserver computer, which has the static IP...
if it does not, buy another one
Posted on Feb 07, 2009
Microsoft Exchange Server. HTTP 500 Internal Server Error.Any recommendations?
To resolve this problem, follow these steps on your Exchange 2000 or Exchange 2003 back-end server. Alternatively, follow these steps on another computer that has access to the same domain controller and the same global catalog server.
NoteThis procedure requires the Exchange Server Fix Toolbox
1.Start the the Exchange Server Fix Toolbox
  1. Right-clickYour_back-end_Exchange_server, and then clickProperties.
  2. Clicknetworkaddressin theAttributeslist, and then clickEdit.
  3. Add a new value forncacn_ip_tcp. Use the FQDN of the server instead of the NetBIOS name or the host name of the server.
    The syntax for this value isncacn_ip_tcp:FQDN. For example, if your Exchange back-end server has a host name of EXCHANGE1 and the FQDN is EXCHANGE1.domain.com, use the following value forncacn_ip_tcp:ncacn_ip_tcp:EXCHANGE1.domain.com
  4. Remove the oldncacn_ip_tcpvalue that contains the NetBIOS name or the host name of the back-end server.
  5. Apply this change.
  6. Because your Exchange computer may change this value back during a failover or a system attendant restart, configure the following registry value on both nodes of the cluster:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchangeSA\Parameters\UpdateProtocols
  1. Right-clickUpdateProtocols, clickModify, type0in theValue databox, and then clickOK.
  2. If your network uses a Hosts file on the back-end cluster node, modify it by using the following order of entry:
  3. Restart the Exchange services on the back-end cluster node.
  4. If there are multiple domain controllers, wait for replication to occur before you try to log on from the front-end server. If the problem is not resolved after replication is complete, restart the IIS Admin Service on the front-end server.
You can obtain the Exchange Server Fix Toolbox by visiting the following site: https://www.fixtoolbox.com/exchangeserverfix.html
Jul 27, 2015 | Microsoft Exchange Server for PC
How to write script in 2003 domaincontroller
lease follow steps to resolve your issue
First, open "Active Directory Users and Computers" on the domain controller
Now right click on the user you want to have the logon script and select the properties menu.
A properties dialog like the one shown below will appear. Select the ‘Profile’ Tab
Here is the confusing part. If I just put any old batch file name in the logon script field, where does windows try to find it from?
Lets find out. First, type in this field ‘logon.bat’
Click OK.
Now, we need to find the folder where the server loads logon scripts. It follows this format:
\\(SERVERNAME)\sysvol\(DOMAIN NAME)\scripts
So, if my server was named DCServer1, and my domain was intelliadmin.com, we would browse to this path:
\\DCServer1\sysvol\intelliadmin.com\scripts
Now that we know where to put it, creating the script is easy. Just open up notepad, and write your batch file. For our test batch file we will put in a line that loads our profile generator for Microsoft Outlook XP
We are done with the script, so we save the text file as:
\\DCServer1\sysvol\intelliadmin.com\scripts\logon.bat
Now, the next time this user logs in, they will load the login script.
hope it can resolved your issue
thanks
May 14, 2010 | Computers & Internet
Hi
please follow steps to resolve your issue
Click OK.
Check out our Windows Admin Tools
Filed Under: Windows
thanks for using fixya
Mar 25, 2010 | Computers & Internet
What is system error 5 ?
The following reasons may cause to the error message:
1. Time Synchronization problem.
2. Missing permission to access the remote computer (Share, NTFS, GPO).
3. Firewall and/or third party product may eliminate connection to the remote computer.
4. The computer account isn't disable (Or have expired computer account password)
or doesn’t exiting in the domain.
5. Active Directory replication problem may occur.
  1. Verity correct time zone and clock synchronization:
Windows Time Service Technical Reference
http://technet2.microsoft.com/WindowsServer/f/?en/Library/a0fcd250-e5f7-41b3-b0e8-240f8236e2101033.mspx
2. Verity correct permissions on the remote host.
Tip: A useful that can be used is: (GPResult.exe) Command Line Tool
How to Use the Group Policy Results (GPResult.exe) Command Line Tool
http://www.microsoft.com/windowsxp/using/setup/expert/gpresults.mspx
3. Open the required ports on the remote computer.
4. Verity that the computer account is active and the computer connect to the domain.
Tip: A useful that can be used is: Netdom.exe Command Line Tool
Netdom.exe
http://technet2.microsoft.com/WindowsServer/en/Library/460e3705-9e5d-4f9b-a139-44341090cfd41033.mspx?mfr=true
5. Verity correct replication in the Active Directory Replication.
Troubleshooting File Replication Service
http://www.microsoft.com/technet/prodtechnol/windows2000serv/technologies/activedirectory/maintain/opsguide/part1/adogd11.mspx
Feb 26, 2010 | Microsoft Windows XP Home Edition
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
Ans
this is not a sufficient to answer. but, you can get some idea in the following information:
if you have a plan to install AD:
  • install AD using manage your server wizard. (or)
  • install AD using DCPROMO command
After, you have to follow the AD installation instructions to store the ntds and sysvol files.
installing dns, is also need for a domain to adding clients.
after this, you can get your desired domain controller and active director users and computers information.
i think, this may be useful for you.
thanks,
Feb 12, 2009 | Microsoft Windows Server Standard 2003 for...
I have insttall A D but not open the active directoryes user & computer
If you are using server 2003, please check it out where the ntds and sysvol files are stored, when installing ADS.
You have two option to view the successfull AD:
  • opening AD users and computer on Administrative tools.
  • viewing Domain option (xyz.com), when you logon to an account.
if, these process are not available for you. There is no option other than reinstalling ADS using dcpromo.
thanks,
Jan 19, 2009 | Microsoft Windows Server Standard 2003 for...
\SYSVOL
________\domain
________\scripts
________\staging
Apr 25, 2008 | Microsoft Windows Server Standard 2003 for...
Backup DHCP,AD of win 2000 .
How To Use the Backup Program to Back Up and Restore the System State in Windows 2000 var sectionFilter = "type != 'notice' && type != 'securedata' && type != 'querywords'"; var tocArrow = "/library/images/support/kbgraphics/public/en-us/downarrow.gif"; var depthLimit = 10; var depth3Limit = 10; var depth4Limit = 5; var depth5Limit = 3; var tocEntryMinimum = 1; .toc{display: none;} SUMMARY loadTOCNode(1, 'summary'); This article describes how you can optionally back up the system state in the Windows 2000 Backup program to back up and restore critical system data. When you choose to back up the system state on a domain controller, the following items are included: • Active Directory (NTDS) • The boot files • The COM+ class registration database • The registry • The system volume (SYSVOL)When you back up the system state on a non-domain controller, the following items are included: • The Boot file • The COM+ class registration database • The registryWhen you back up a member server or domain controller with Certificate Server installed, the following additional item is also included: • Certificate ServerWindows 2000 Backup can back up and restore Active Directory on Windows 2000 domain controllers. You can perform a backup operation while the domain controller is online. You can perform a restore operation only when the domain controller is booted into Directory Services Restore mode (by pressing the F8 key when the server is booting).
uparrow.gifBack to the top
How to Back Up the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 2. Click the Backup tab. 3. Click to select the System State check box. (All of the components to be backed up are listed in the right pane. You cannot individually select each item.)
NOTE: During the system state backup, you must select to back up the Winnt\Sysvol folder. You must also select this option during the restore operation to have a working sysvol after the recovery.The following information applies only to domain controllers. You can restore member servers the same way, but in normal mode.
If any of the following conditions are not met, the system state is not restored. Backup attempts to restore the system state, but does not succeed. • The drive letter on which the %SystemRoot% folder is located must be the same as when it was backed up. • The %SystemRoot% folder must be the same folder as when it was backed up. • If sysvol or other Active Directory databases were located on another volume, they must exist and have the same drive letters also. The size of the volume does not matter. uparrow.gifBack to the top
How to Restore the System State on a Domain Controller loadTOCNode(2, 'summary'); 1. To restore the system state on a domain controller, first start the computer in Directory Services Restore Mode. To do so, restart the computer and press the F8 key when you see the Boot menu. 2. Choose Directory Services Restore Mode. 3. Choose the Windows 2000 installation you are going to recover, and then press ENTER. 4. At the logon prompt, supply the Directory Services Restore mode credentials you supplied during the Dcpromo.exe process. 5. Click OK to acknowledge that you are using Safe mode. 6. Click Start, point to Programs, point to Accessories, point to System Tools, and then click Backup. 7. Click the Restore tab. 8. Click the appropriate backup media and the system state to restore.
NOTE: During the restore operation, the Winnt\Sysvol folder must also be selected to be restored to have a working sysvol after the recovery process. Be sure that the advanced option to restore "junction points and data" is also selected prior to the restore. This ensures that sysvol junction points are re-created. 9. In the Restore Files to box, click Original Location.
NOTE: When you choose to restore a file to an alternative location or to a single file, not all system state data is restored. These options are used mostly for boot files or registry keys. 10. Click Start Restore. 11. After the restore process is finished, restart the computer.
Dec 02, 2007 | Microsoft Windows Server Standard 2003 for...
Replication
You need to either use a Domain Account if you are using Windows authentication or you need to use SQL server authentication.
The reason for this is because the user account that you are using only exists on the machine that you are on not on the machine that you will be replicating to.
Sep 24, 2007 | Microsoft SQL Server Standard Edition for...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
