Question about Refrigerators
How to fix sanden intercooler model cpw0311
The fidge is on but the fan at the bottom is not working but the uppper fan is working. pls help
2 Suggested Answers
  • 43501 Answers
SOURCE: top freezer works fidge warm
Here are a couple of tips that I wrote that will help you figure this out...
Posted on Apr 19, 2010
How do I remove the intercooler from my 2007 Santa Fe 2.2CRDT?
maybe the radiator? the thing that sits in front of the engine with the fan aimed at it? in that case, youll probably have to take off the fan housing, drain it via the drain plug at the bottom left or bottom right of it (dont do that if you have had the engine running recently itll burn) let it drain. take off all of the hoses connected to it, then it will be secured somehow around the edges, undo those points and it should come out. id suggest taking another approach at getting the 4th screw out however. smaller/different angled tools often do the trick
Oct 20, 2012 | 2007 Hyundai Santa Fe Limited
05 golf 1.9D TDI engine code BKC
Check the seals on the intercooler, for oil to get in the pipes means that the seals are damaged and its loosing compression
Jul 16, 2008 | 2005 Volkswagen Golf
Fridge part not cooling but the freezer is fine
Sounds like one of the fans aren't working. The fans only work when the both doors are shut. Shut one door and use a strong magenet on the magenetic sensor ( located on where the door shuts in between the two doors. Shaped like a lump that sticks out). Put your hand to the back wall of the fridge (or to the fan in the freezer) and see if there is air movement. Is there isn't then its the compartment your in's fan.
If they are both working then it could be your freezers de-ice element not working or your fidge my need to be switched off to defrost
Mar 21, 2011 | Fisher and Paykel Active Smart E522B...
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
I bought a NYKO intercooling fan and the plug from the xbox 360 elite will not go into the fan receptacle is there a specific intercooler for the elite?
Microsoft has two different power connections for the Xbox 360. I do not recommend the use of the Intercooler. Believe it or not, it actually prevents air from circulating and increases the temperature of the 360!
For cooling I always recommend the fan modification. I have written a free guide showing you how to do this, no soldering skills required!
Here is the guide.
Hope this helps! Let me know if you have any questions.
Dec 29, 2009 | Nyko Intercooler for Xbox 360
Range rover p38 radiator removal info
First, remove the grille, then the top panel. Remove the viscous coupling and fan. Remove the top radiator mounts, Remove the coolant hoses and oil pipes, remove 4 bolts holding the A/C and intercooler/or PAS radiators (depending if yours is diesel or petrol.) then lift up and out the radiator. Fitting is reversal of removal.
Hope this helps
Nov 20, 2009 | 2000 Land Rover Range Rover
Samsung fridge freezer
there is a shaft from freezer to fridge that the cold air travels. make sure that is unblocked. also make sure the fan is working. then see if the freezer coils are iced up (this restricts air flow). if they are, unplug it, empty the fridge and freezer, defrost the coils, dry it out, plug it in and turn it on (not high). once it reaches the temp and the compressor stops, fill the fridge again.
Jul 30, 2009 | Samsung RB215LASH
Fidge freezer is not working properly
Get british gas homecare cover for heating and appliances, don't tell 'em the freezer isn't working, then a month later report it as a fault, they'll fix it. Unscrupulous i know but what can ya do? Otherwise get a hotpoint engineer, sign up for their maintenance plan.
Apr 04, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Very hot compresser upside down fidge
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Feb 16, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
