Question about Toys
Bobcat s130 will open bucket but wont close. drives and steers fine and will also lift with no issues
2 Suggested Answers
  • 3519 Answers
SOURCE: How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Posted on Sep 23, 2015
Testimonial: "I did remove three of the hoses at one time simply two of the hoses were rubbed through and to remove one of the ones I had to remove another to get at one rubbed through. However I am 100% sure they are installed correctly because only two of the hoses are the same diameter and they run parallel to each other and one has to be installed before you can install the other. Thank you for your help. I see I need to get more hydraulic fluid as my level went down after trying system. Joe"
Clark 753 bobcat front bucket rams wont open or shut
check for correct fittment of the quick release hose connections
if they are not together properly the valves block oil flow
check for control valve operation if electronic operation
Feb 06, 2017 | Bobcat Garden
I'm looking for a manual for bobcat s130 serial number 527314309
If you are looking for a repair manual for this machine I have found a place where you can order one. I have included the link here. Bobcat S130 Repair Manual Skid Steer Loader 529211001 Download
Feb 04, 2016 | Bobcat Garden
How do i fix my bobcat 825 skidsteers hydraulics ? the right steering leaver works fine but the left does very little to nothing.
basically there are 2 points of control
1---is the control valve for that side which may not be opening the system
2--- the drive motor for that side which may be passing excessive oil and not turning
for the lift action to be slow indicates excessive pressure leakage in that circuit
early units had lever action to the control valves where as later units use electronic controls from joysticks to operate the valves
If this is your type of machine, I would be looking at faulty electronic control mechanisms or corroded wires and contacts
Dec 15, 2015 | Bobcat Garden
Why wont my bobcat lift bucket
Hi John:
This is in the toys category.
If you're like me, and it is a real working bobcat, I understand. All of my machines are toys.
= So, assuming this is a really machine, you'll be dealing with a hydraulic problem, and if it were me, I'd be trouble shooting sort of like this:
WORK SAFE - All hydraulics lowered, machine off.
1) Check hydraulic tank fluid level.
2) Look under machine for any signs of leakage
3) Check all hoses, cylinders, and concealed spaces for signs of leakage.
4) Check pump for signs of leakage, make sure drive is engaged.
Please reply to this post as a comment and we'll carry on unless you've spotted the problem.
Cheers.
Nov 30, 2015 | Toys
Hi Joseph:
Sep 23, 2015 | Toys
Toys Logo
32 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
