My washer is maintaining water and continues to run after the cycle is complete?
    Problem Solver:
  • 16 Answers
You have problem with pomp or swich put pomp to work .Replays pomp or switch.
Posted on Dec 12, 2016
KENMORE DISHWASHER, WATER CONTINUES TO FILL AFTER WASHER IS SHUT OFF.
You're correct you have a faulty water inlet valve. At the end of the wash cycle the solenoid in the valve is not closing properly to not allow water to re-enter the tub. For further assistance with this repai
Jan 21, 2014 | Computers & Internet
The water continues to run into my Maytag Ensignia after the cycle is complete
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Oct 05, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
My GE washing machine smells of meldew, I don't see water in it but when I shake the machine i can hear the water sitting at the bottom. How do i drain this water and also how do i get to it?
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Jun 05, 2009 | Indesit W 123 Front Load Washer
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Dishwasher will not run through its cycle
Hi
If the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Washer ultimate 11
probably bad fill valve ..if water continues to run in when machine is off valve may not be shutting off completely due to trash if screen in cold inlet has been removed to clean and not reinstalled trash can enter valve and prevent complete shut off ..remove 2 screwson back of console pull console forward and roll back pop 2 clips 1 each corner remove lid switch plug cabinet will lean forward and off to acess valve
Sep 02, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer continues to drip into tub after cycle in complete.
contstant water dripping into tub sounds like a bad water valve, no repairing valve just replace it
Feb 25, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Lg washer
funny enough LG water inlet valves are favorite for that problem. if you put the power off and the water still flows into the tub then the valve needs to be serviced. if it goes off when power is switched off but continues to fill after cycle is complete then board needs replacement.
May 28, 2007 | LG WD-1280FHD Front Load Washer
Cold water continues to run during entire wash cycle
Adrea, sounds like you need a new valve. When it's doing this leaking, unplug the washer. If it's still leaking you know for sure it's the valve. Part number for the model posted is 22002360. Catriver..post back.
Sep 30, 2006 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
