SOURCE: toshiba 42HP66, HDMI problems
Your Cable box might need to be reprogrammed. Call the cable company and they will drive you thru the steps to program it, this way you will get the channels. This process might take you 30-45 minutes.
Artgirlny
SOURCE: Getting the TV to play through the HDMI cord
First, you need to set the playstation to display on HDMI out.
Plug the HDMI cable into the TV and into the PS3.
Use the PS3 to setup the video settings to 720p which every HDTV can display. Then switch the TV-out to HDMI and it should display.
Also consult your televisions manual to set it up for HDMI input as well. Make sure that the TV allows sound through the HDMI port as some older HDTV's didn't have that ability.
If you still have a problem; please let me know! I hope it helps you out
SOURCE: i have mintek dtv 265-d lcd 26in
Have tried the remote, most new tvs have a control panel lock that can accidently be activated, it usually takes the remote to undo the lock.
Let ne know.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: how to program comcast remote with my toshiba 19hlv87
with comcast remote with red ok select switch the toshiba codes are 11256 most likely, other codes are 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast remote with grey ok select swithc the toshiba codes are 0154, 0156, 0060
Dale
SOURCE: How do I add a channel to the toshiba 19hlv87 when
you need to go into menu then setup then auto program
