Question about Toro Garden
My Toro 724 snowblower worked fine two weeks ago. Today when I tried to put it into forward or reverse the engine died. When I tried to let it go into gear slowly it started to smoke so I quit. Help
    Top Expert:
  • Toro Master
  • 49,126 Answers
Sounds like the auger is frozen
Posted on Dec 12, 2016
My toro 724 2 stage snowblower wil run fine until it gets hot. It will die and I have to choke it to restart it will run for about a minute and die again
I would suggest if there is an adjustment screw on the carb turn it open a little bit at a time till it keeps running. Left is open. If that does not work take the fuel jet out and clean it. If there is a fuel cup on the bottom of the carb remove it and clean it out as well. Try the adjusting screw first if you can. Make sure you have fresh clean gas as well.
Dec 26, 2016 | Garden
Why I have a toro snowblower model#38272 that started a couple weeks ago and now will not start
Check wires for insulation damage. Spray Carb Starter Fluid into manifold and see if that gets the machine to turn over.
Feb 03, 2015 | Toro Garden
Problems shifting toro power max 726 oe snowblower
adjust the cable easy to do , get the manual or just look good at it ,
Feb 04, 2014 | Toro Power Max 726 OE Snowblower - 37771
My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Dec 04, 2011 | Garden
Will not go in gear, except park
check the level of the fluid first. Could be that's all it needs.
Jun 30, 2009 | 2004 Ford Freestar
Toro 724 snowblower won't start
One of two things will cause this. Either your piston rings have fried and your piston is stuck. The bearing on the flywheel is bad. Or actually one of thing, the crank shaft has broken. You willl need to take the motor apart all the way and see what is going on. If you take the flywheel off try to turn it by hand and see if you can turn it that wy. You also can try easier to check for first symptom is to make sure you are not in vapor lock. Remove the spark plug, turn unit upside down and see if you can get the motor to turn, if you can then replace the spark plug and it will start up. You can getvapor lock by running it low on fuel or the wrong fuel or running it to rich
Feb 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I have a toro ccr 3650 snowblower the electric start just grinds
This problem has been solved! I took the covers off the machine, removed the starter and eventually replaced the drive. Apparently the drive parts were put on back ordered and took about 4 weeks to get the drive set. One thing I suggest if anyone does this is to look at the fly wheel to insure it's in good working order. The dealer I worked with said often that is chewed up (the teeth on the fly wheel) and leads to a bigger headache. Fortunately mine was just fine. The machine now works likes like new as I put in a new spark plug as well!
Dec 01, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
48 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
