Question about Cameras
Batteries short out when off and run down. cap has a small dent is that the problem can I get a new back cap Its a 4 3 volt battery high lumen flash
  • Cameras Master
  • 5,412 Answers
What make is your flashgun, and to which make and model of camera are you attaching it ?
Posted on Dec 12, 2016
How to charge Coast PX45?
not a rechargable light .put in new batteries
Jul 01, 2016 | Coast PX45 LED Flashlight
When my E2d. Ed defender. 200 lumens flash light is turn on it act like an strob light how to stop it or is it a weak batteries
No, that is a 'feature'. It is for signalling or blinding an attacker.
This is the instructions for the 500 lumen version but it will be the same. Nice light, I run Fenix Tactical. Strobe is usually gained by switching on and then half depressing the button and holding. If this doesn't work, contact Surefire direct.
The E2D LED Defender® Ultra is a compact 500-lumen flashlight featuring dual-output capability and self-defense enhancements. Utilizing a virtually indestructible high-performance LED and a Total Internal Reflection (TIR) lens, the E2DL Ultra is activated with a pushbutton tailcap click switch that also selects output levels: press or click once for a high-intensity 500-lumen white-light beam-ten times the light needed to overwhelm the night-adapted vision of an aggressor. Return to off and press or click again within two seconds for a 5-lumen ultra-long runtime low beam that's suitable for navigating at night or performing close-up tasks for hours. The Defender's crenellated Strike Bezel® provides further defensive options should the need arise. Slender and powerful, the E2DL Ultra is an ideal everyday-carry light.
Jan 08, 2016 | Surefire E2D LED Defender Flashlight Max-...
Red light flashing without battery on craftsman c3 19.2 volt charger
There are many possibilities, but one I found was a short between the terminals on the small square logic chip. With the power off, take a sharp tool like an exacto knife and lightly swipe it between the pins on the chip being careful not to cut any circuit board runs. I used a probe small enough to fit between the pins and scraped all of them clean. I think it was some corrosion that caused a resistive short. I have some other chargers with the same problem, but this solution did not work for them.
Feb 01, 2013 | Craftsman C3 19.2 volt Lithium-Ion Battery...
Ezip 500 won't run : new batteries fully charged but it still shows low battery light...what else could be wrong
i'm having the same problem. checked fuses and both are good. going through the wiring harness to look for shorts. have a bad feeling the micro controller died, that is the little plastic box with metal fins on it under the seat post behind the batteries ******* to the frame. i can bypass the micro-controller and connect one 12 volt battery directly to motor and runs full speed. somehow it is wired with 2 - 12 volt batteries in series to give 24 volts and them the processor cuts back down to 12 volts to run the motor. not sure why this is engineered this way? still working the problem. what sucks so far is that the micro controller is encased in resin so it is virtually non repairable.
* Update added.
Found these wiring harness for sale online scooter stores and on ebay. I replaced mine with some intermediate level adapting the harness to my model scooter and this includes some soldering and wire splicing changing power connector heads off old harnedd to new harness to fit bike. Works great.
Jan 02, 2013 | UPG New Replacement Batteries 4 EZIP E Zip...
My 1998 cbr rr honda motorcycle battery is not charging
Do you own a volt meter?
Get a voltage reading from the battery while the bike is off (the resting voltage). A short cell should prevent you from ever reading anything more then 10.5 volts. If the battery is 12.2 volts or less, it's discharged. Fully charged is 12.8 volts.
Next, start the bike (or jump start it if the battery is down) and take a voltage reading while the bike is on. The Voltage should go as high as 14.8 volts. That's normal. If the battery is down, it will have to climb up to that point.
I got this info from here.
Aug 03, 2012 | 1998 Honda CBR 900 RR Fireblade
My asus Eee1005H runs ok, with power adapter., the orange light lumen ok . As the power adapter pull out,the note book fully powerd off. I opend the Battery to find bed or open cell,but i found that...
I should buy a new battery. It may have a short circuit cell and work fine on 12Volts.
Don't put the old one in the dustbin, take it to a recycling centre to avoid poisoning people in 50 years time.
Dec 15, 2010 | ASUS Eee PC 1000HE Netbook
Battery light & brake light flashes on & off. went to parts store & had battry & charging system checked. was told battery was bad , bought new one .problem still there not as bad...
You need to get a volt meter on it. Your battery should be around high 12 to 13 volts while not running, and increase a little without going over 14 1/2 volts running.
Aug 11, 2010 | 2007 Nissan Titan LE
Batteries die fast on my mobility scooter.
Hi. What size batteries you buy will be limited to the amount of room you have in the machine.
17 amp hour batteries are really a bit small for any mobility equipement. A lot of power chairs have 35 or 40 amp/hour batteries.
Buy the biggest that will fit into the available space.
Batteries are designed to perform a certain number of "charge cycles". If you run your batteries down by 75%, you will only get a small number of "charge cycles". If you only use 25% of the batteries capacity, you will get 100's of "charge cycles".
The best I have seen is 7 years out of a set of batteries. Short trips and recharging after each trip is the reason.
Good luck. Neil.
Jun 03, 2010 | Electric Mobility Pacesaver Electric...
2002 monte carlo will not charge has a new battery and a new alternator has 12 volts going to the big post and 12 volt going to 1 of the 2 small wires
You need more than 12 volts to charge the battery. How many amps does the alternator put out? This is what charges the battery.
Aug 18, 2009 | Chevrolet Monte Carlo Cars & Trucks
Vivitar 285HV Stop Working
There is nothing wrong with your flash unit. The regular AA batters are 1.5 v volts each- if 4 batteries are used that is a total of 6 volts for proper operation. The rechargeable batteries are 1.2 volts each and 4 will get you 4.8 volts- thats 1.2 volts short and that is probably the root of our problem .
Try recharging you rechargeable batteries and put the im one more time- if the same problem happens you will have to stick with standard AA batteries. There external 6 volt packs that will work with your flash unit0 the are a bit of an expense at first but you will save on replacement batteries in the long run,.
Nov 27, 2008 | Vivitar 285HV Flash
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
