Question about Lucien Piccard Watches
Lucien piccard 27096 WHD soulmate classic diamond watch is it vintage or pre-1968?
  • 2334 Answers
SOURCE: Add links to a Lucien Piccard 26006SS
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
  • 1970 Answers
SOURCE: how to size a lucien piccard mens watch bracelet
mcdevito75 here, Best bet, look for a small watch repair shop in your area to help fit your watch and to save on the cost.
Posted on Jun 18, 2010
  • 1970 Answers
SOURCE: how to fix lucien piccard watch
mcdevito75 here, Depending on the problem, check out the Repair/ Services here on fixya, at the bottom of this page, once at Repair Services type in watches.
Posted on Jun 21, 2010
  • 2334 Answers
SOURCE: how do i remove links from a ceramic lucien
Browse through my Tips and Tricks. There you will find how to add or remove links.
Posted on Feb 25, 2011
  • 794 Answers
SOURCE: Anyone know how to date
Hi tmacar,
Kindly refer to this link for the instruction on how you can set date for your Lucien Piccard Circa 101 automatic watch.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 03, 2011
Whats the value serial number 980512 lucien piccard
Probably not what you paid for it, sad to say. So many were made, and with the recession and the advent of a reliable timepiece in everyone's pocket anyway, the collector's market for elegant wristwatches has declined somewhat. It also varies dramatically depending on what kind of market you're selling in. Pawnbrokers, jewelers, and watch collectors all have different ideas of how to determine a piece's value. Condition and provenance also play a large part of any appraisal. I wouldn't accept less than $250 if I were you, but I wouldn't expect more than $500. In the long run, your best bet to have it keep its' value would be to keep it until it can be classified as vintage or an antique. Once most of the other Lucien Piccard watches that were made at the same time as it was have failed, been melted for gold or lost, the value will start to go up again, and if you or your family can keep it for a VERY long time indeed, then it's definitely possible to make a profit on a watch.
Aug 31, 2012 | Lucien Piccard Watches
I have a lucien piccard watch, purchased probably in the 70's. Would it be water resistant?
Yes, I think that your Lucien Piccard Watch is water resistant until now as long that the gasket of the caseback is still intact. and for you to find out that the gasket of your watch is still intact then, you should bring your watch to the expert to check your watch gasket. i hope i solve your problem.
Jul 09, 2011 | Lucien Piccard Watches
Looking for a leather band for a lucien piccard
i only found some for women sorry !!!
Nov 09, 2010 | Lucien Piccard 26024 Wrist Watch
How to fix lucien piccard watch
Jun 20, 2010 | Lucien Piccard 14K Solid Gold & Diamond...
How to size a lucien piccard mens watch bracelet - model 26932wh
Jun 15, 2010 | Lucien Piccard 26024 Wrist Watch
Need New Watch Band
i have repaired watches like this before. I advised u to go to www.the and or there u can buy and choose branded lucien piccard watch band.let me know if u see what u wanted...
Jun 14, 2008 | Lucien Piccard Watches
No problem - who is the manufacturer?
They are made by the LP Watch Group, from their website: "The LP Watch Group has been handcrafting fine watches for generations. Founded in 1923 in Switzerland, by the Lucien Piccard family, the timepieces of the LP Watch Group have adorned royalty, dignitaries and celebrities world-wide. Today, The LP Watch Group has repositioned itself for the 21st Century as a leader in the branded watch arena by collaborating with new young and talented designers offering some of the most innovative designs in the world. We have combined art and fashion with superior technology and handcrafted quality. The LP Watch Group continues to provide old world craftsmanship in our classic watch designs, as well as technically innovative and boldly styled watches for our LP Italy Collections. Timepieces from the LP Watch Group are manufactured in materials such as 14 and 18 karat gold, sterling silver and Italian stainless steel. Diamonds and precious stones of the highest quality are incorporated into many of the watch styles. Originally renowned for its classic gold precision timepieces, in recent years The LP Watch Group has broadened its lines to incorporate distinct collections such as LP Italy?, Lucien Piccard?, and many others." You can see your watch on the link below: Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 12, 2007 | Lucien Piccard 26487BRNO Wrist Watch
Watches Logo
20 people viewed this question
Top Lucien Piccard Watches Experts
Greg Cann
Greg Cann
Are you a Lucien Piccard Watch Expert? Answer questions, earn points and help others
