Question about Dell OptiPlex GX270 Small Mini-Tower Desktop (162823025)
Optiplex gx270 freezes in upright position. purchased stand and now dell freezes during boot.
  • 24 Answers
You might have something loose inside. have you opened it and checked for cables that might be rubbing against a fan or even a loose card in a slot.
Posted on Jul 20, 2009
Guide for setting bios options ?
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow keys navigate through options.
Apr 20, 2013 | Dell OptiPlex GX270 PC Desktop
How Do I get into Safe Mode on a Dell OptiPlex GX270 PC Desktop
Turn on your computer, as soon as you press the power button, begin tapping the F8 key. A menu should come up. Using your arrow keys navigate to the safe mode option.
Jan 20, 2013 | Dell OptiPlex GX270 PC Desktop
My Dell optiplex gx270 makes noise after i installed windows vista it has become slow too
Check your HDD it might got some bad sectors/tracks, mostly noise comes for that only
Aug 24, 2012 | Dell OptiPlex GX270 PC Desktop
Hi my Dell OptiPlex GX270 turns on but when it comes on it freezes but i cant be sure its frozen because my mouse and keyboard wont connect I orginally bought a wireless mouse and keyboard and it wouldnt...
First off, try going to BIOS. Usually you have to tap either F2 or Delete on dell computers while booting up to enter BIOS. If you're successful, and you're in BIOS, observe for a few minutes if it will freeze while in BIOS. If it doesn't then you might need to reinstall windows. If it freezes in BIOS as well, then there's a hardware malfunction/problem. That will be the time to have a technician check the hardware on your desktop.
Regards..
Sep 11, 2011 | Dell OptiPlex GX270 PC Desktop
Failed at checkpoint [PnP1]/ dell optiplex GX270 series
PCI Slot 1 problem it appears. This means opening the case and reseating all the above-board cards such as video, audio, ethernet, etc.
Shut down the computer and unplug it. Press and hold the power button for a slow count of at least 10. Then you may open the case. How your case opens depends on the model. If this computer is what I think it is and you're unfamiliar with going inside the case I would suggest taking it to a repair shop. The Optiplex computers I've been inside of of are awkward to work with.
Feb 25, 2011 | Dell Optiplex GX270
Booting failed at checkpoint [WRIT}
May be a cpu problem. Make sure the fan is on the cpu and that it is running. If the fan is running you may need to change the thermal compound that is between the cpu and heat sink. If that doesn't work , the next step would be to try to use another cpu that you know is good and see if it fixes your problem.
Nov 01, 2010 | Dell Optiplex GX270
How do I know if this cpu has a network card?
The Dell GX270 small form factor has an integrated NIC card that is built into the motherboard.
May 15, 2010 | Dell OptiPlex GX270 PC Desktop
Dell Optiplex GX270 lockup and s3 standby lockup
have you tried changing your boot sequence (setting your hd as first boot source?) in set-up?
just asking- if you still have cd as first boot device, it should go to second choice (hd?), with no problem, but you might try re-setting to manufacturers settings, and go from there! is it set for pnp support? check all this stuff!
amber means 'standbye- or sleep mode'- tapping a key, or mouse button should bring it out. every manufacturer has their 'little quirks', that can be confusing!!
good luck!
Oct 09, 2009 | Dell OptiPlex GX270 PC Desktop
Dell Optiplex GX270 - Freezes up!
You may have either a memory chip gone bad or the CPU overheating. Withot seeing it and testing it's hard to tell you which. But one thing you can try is if you have 2 RAM installed, try to remove 1 and see if the problem continues. If so, change them and put the one you removed back and remove the other. if it continues then you may have an overheating problem.
Otherwise, you can try a SCANDISK and DEFRAG to clean up the hard drive and data.
Jun 19, 2009 | Dell OptiPlex GX270 PC Desktop
Memory
Hi
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Mike
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
199 people viewed this question
Alun Cox
