Question about Pool & Spa
I have a 660 1hp onga pool pump how do i dismantle so i can fit new seal kit thank you
5 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: water leaking
some times you need two people one to hold the shaft the other to turn impeller on you need to put in a vice wraped in a towel and not to tight or break it off and replace it to
Posted on Feb 11, 2009
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
  • 22 Answers
SOURCE: onga ltp400 pump , unable
It's a matter of removing the main casing, impeller, diffuser, seal assembly, baffle, shaft sleeve, fan cowl, fan, motor end shield and rotor in that order - which part of this procedure are you having trouble with?
Posted on Jan 09, 2011
  • 22 Answers
SOURCE: My Onga PPP1100 pool pump
Depending on its age, it may have been fitted with the wrong thermal overload when it was manufactured. If it is relatively new go back to your supplier for a fix; if it is not new please tell us more about the problem..
Posted on Jan 24, 2011
Can anyone give me a # that works for Utilitech? I need a Impeller and diffuser kit and Lowes where we bought it from isn't any help, the number I have for Utilitech is busy...Thanks!
pump impeller and diffusers are available from any pump repair shop
find the brand name of the motor /pump ( onga, davey or the like ) and find a pump shop that handles that brand and they will have what you want
Jun 07, 2016 | Pool & Spa
How do I fit a seal to an Onga JSP110, and what way does it go in?
Try to get an operator's manual from the dealer, or Google Onga JSP110 seal replacement.
Aug 11, 2015 | Plumbing
I cannot start pumping. the pump runs but no water is circulating
I think you have spun the center out of your impeller. Disassemble your pump and replace the impeller if necessary. Also replace all seals while you are at it.
May 04, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
My Onga PPP1100 pool pump cuts out every 5-10 mins then restarts after 5-10 mins.
Jan 22, 2011 | Pentair Pool & Spa
Onga ltp400 pump , unable to dismantle to change beariings
Jan 09, 2011 | Pool & Spa
Onga sand filter pumps sand in to pool ,just got re connected to new above ground pool
The lateral(s) are damaged and allowing sand thru and back to the pool. I have never dealt with that specific brand to know if the laterals come as one assembly or individual pieces. You'll need to contact the dealer you got the unit from or check online at http://www.onga.com.au/dealerlocator for someone in your area.
Dec 05, 2009 | Pool & Spa
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
PS-1000 Seal
The seal replacement on most pumps requires the capacity to separate the motor from the pump and to dismantle the wet end. Upon dismantling, it will become clear as to where the seal components are to be replaced. The spring half is found in the seal plate and must be knocked out and reinstalled with a properly sized driver and the ceramic seat is attached to impeller. Be careful not to damage the polished surfaces of seal. A light coating of a silicone or teflon based lubricant is most helpful ..
Apr 12, 2009 | Waterway Pump Part Seal Set Ps1000 Cd 319...
Water leaking
Jan 24, 2009 | Pool & Spa
Pool & Spa Logo
46 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
