Question about Garden
How to replace the tiller boot on GC240? - Garden
Do you have or can you find Agrator Rototiller Gears ?
Agristore USA ' Replacement Parts ' Agrator Tiller Blades
www.agristoreusa.com/collections/agrator-tiller-blades
Tiller Blade for AGRATOR D-UR $6.75 · Tiller Blade for AGRATOR D-UR $6.75 · TillerBlade for AGRATOR D-UR $8.50 · Tiller Blade for AGRATOR D-UR $8.50.
Sep 25, 2015 | Garden
How do i fix a tiller that will not lock in places
That is the same problem I had on my Pride Legend Xl. I bought
used. Tiller mechanism switch and cable would not lock the mechanism down below. I tried a few things to just lock it in the upright position permanently, finally I discovered the only way to "lock" the tiller, was to use a huge automotive 3-6 inch diameter
hose clamp, and install it inside the rubber boot at the bottom of the tiller to tighten around the tiller tilt mechanism and prevent it from
tilting, and that has worked for me. The lock mechanisms seem to be prone to failure on some models and the cost of repairing them is very expensive.
Nov 02, 2014 | Golden Technologies Golden CompanioN II -...
Replacing the throttle boot, I think
hi , I can order the part however i will require the serial number ,
regards
Jan 23, 2013 | Pride Mobility Legend 4 Wheel Electric...
I have no spark checked switch and replaced plug what else should I check
Check the coil. Pull the boot off of the plug. While holding the boot near a metal surface, darken the room and pull the starter rope. If you see a spark, the coil is good, if you don't, you just found your problem.
Sep 04, 2011 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
I have to replace the rubber boot on the tiller is there a repair manual for that
You can call Pride Mobility 1-800-800-8586 They should be able to help you.
Good Luck
Tim
May 02, 2011 | Pride Hurricane 4 Wheel Personal Mobility...
Troy-bilt tiller
The only way to roll around is to remove the pins on the axle and slide the wheels in and replace the pins. If this has never been done sometime its rather hard to do. Hope this will help
Apr 25, 2010 | Troy-Bilt Pony Garden Tiller
Tiller safety tips
* As with any garden equipment, especially gas-powered, you should make sure you have adequate protective gear. * Safety goggles, work gloves and earplugs are all necessities. * Wear sturdy, steel-toed boots if you have them; if not, wear your most durable close-toed footwear. * If you plan to be out in the sun for a long time, don't forget a hat, sunglasses and sunscreen too!
Aug 27, 2008 | Mantis Crevice Cleaner Attachment
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
