How do i get to the switch on the washer on frigidare stackablehow to fix switch on stackable washer and dryer
  • 5911 Answers
SOURCE: seperate washer and dryer
Unfortunately, your washer and dryer are part of a "laundry center". Which means, the two together are one system. They cannot be separated. You can still use the dryer, obviously. Have you considered fixing the washer?
Posted on Jun 22, 2007
the dr
  • 447 Answers
SOURCE: Dryer spinning but not heating up
what is the model#???
Posted on Oct 01, 2007
  • 262 Answers
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Posted on Jan 04, 2008
  • 2651 Answers
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Posted on Dec 09, 2008
SOURCE: Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Posted on Nov 15, 2009
Brown Burn Stains and little holes from FRIGIDARE GALLERY HEAVY DUTY STACKABLE DRYER
If you are using LP gas make sure the dryer is set to LP on the regulator. If a natural gas dryer is run on LP you will get way to much flame.
Jan 02, 2014 | Dryers
Hi, my stackable frigidare dryer isn't doing a very good job drying my clothes. The unit is about 3-4 years old, but has only been used for 2 years.
Make sure the vent is completely clear and the air blowing out is a pretty strong flow. It could be a defective thermostat too. Another reason is sometimes the washer doesn't spin the clothes out enough and they are too wet to dry normally.
Jan 06, 2010 | Frigidaire Dryers
Stackable washer/dryer
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Apr 13, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Oct 13, 2008 | Washing Machines
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Open Questions:
Frigidaire GLTF2940ES3 washer cycles/controls out of whack since replaced main control board -- is there a compatibility problem with our 11 year old washer? Bought washer in 2007, Frigidaire GLTF2940ES3. Stopped working, got error code suggesting problem with main control board, so replaced it with new, part# 137006000. Didn't fix problem, got new error code suggesting problem with speed control board. Replaced that with new, part# 134743500. Now washer works at least, all the cycles we've tried do something plausible, but the controls and cycles are out of whack. For example, when I set the dial to normal, it used to show 52 minutes in the display, now it shows 28 minutes. When I set the dial to heavy, it used to show 56 minutes in the display, now it shows 52 minutes. Did they rearrange the dial since 2007? If so, is there a key we can use to translate new dial labels to old dial labels? It seemed like there was only one way to assemble the knob and dial, so I don't think I put it together with the dial in the wrong position. Or is this a common failure indicating that the new main control board is defective? Easy to imagine a defective control board causing one or more cycles or controls not to work; hard to imagine a defect that results in the case we have, i.e. everything working, but cycles scrambled. Our laundry room is tiny and we've got the dryer stacked on top of the washer, so it's a major hassle to get at the main control board major hassle like can't get into the refrigerator or use the back door of the house while the laundry machines are un-stacked. Otherwise I would swap the old one back in and see what happened. Any thoughts or suggestions welcome! Thank you.
Mar 18, 2018 | Frigidaire Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
