Question about Home Security
Trying to hook up an Arlo wireless security 2 cameras with base station The system was bought used was wondering if that is why I can not get it to work.
I have taken all the steps and repeated them several times and can not discover base station.
SOURCE: gigaset 2420 system
I saw a battery for this phone,GH5812 on Ebay for under $5.00 !
Posted on Dec 19, 2007
  • 3422 Answers
SOURCE: I cannot register the handsets
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 21, 2008
SOURCE: Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Posted on Aug 27, 2008
SOURCE: Handset Won't Connect to Base Station
OK sorry guess I was thinking you had 2 handsets.
My suggestion is go to the Uniden website and maybe see what they have there.
Maybe do a search on the Uniden site for that Automatic Digital Security Code thing, seems it would be easy to fix, just a matter of how....
In the meantime I'll do some searching and see if I can help and find a fix
Posted on Dec 01, 2008
cshannon1077
  • 14 Answers
SOURCE: DCT 646
If you have a phone that works off a broadband modem, that is a VoIP phone. That will not work with a home phone line. I'm assuming Verizon is your local Telephone carrier that provides your local dial tone.
The broadband modem would have the phone number of whatever VoIP phone service you have.
Posted on Apr 10, 2009
Hi there, my Motorola Hubble is pointing out of my window to my car and front door but it’s not sending me notifications of movement ie when postman put mail in letterbox ?
Change Cameras' Placement or Pointing Angle Security cameras with built-in PIR motion sensor, such as Arlo cameras could see cameras do detect motion but fail to record or capture movement. Or cameras can't detect or record motions through glass or window glass panel.
In such cases, avoid placing motion detection security cameras behind the glass window especially cameras with a PIR motion sensor; do place wireless motion sensor security cameras closer to a WiFi router or hotspot.
The object from afar is relatively easier to be miss out, so don't expect security cameras to pick up every movement within its field of view. Focusing on strategic areas for motion detection helps achieve maximal peace of mind as well as reducing unwanted false alarms.
https://reolink.com/security-camera-motion-detection-not-working/
Feb 21, 2018 | Motorola Computers & Internet
Alexa not coonnecting to arlo camera
If you are not able to connect your Alexa Device with your camera, Just call at:
Amazon Alexa Device Support Services 1 844 224 0047 Alexa Echo Help
Dec 13, 2017 | Cameras
Wireless router configuration
If you don't already have a wireless network, you can use an AirPort base station to create one. To configure an AirPort base station, you connect the Ethernet connection to the WAN port on the base station. In turn, the base station creates a Wi-Fi (wireless) connection to the Internet. Consult the documentation for your AirPort base station for more information on how to set up your wireless connection. Once you have a Wi-Fi network available, use these steps to tell your Mac to join it:
  1. Click the Wi-Fi menu icon airport_symbol.png and select your Wi-Fi network from the list of available networks.
  2. If prompted, enter the password for your Wi-Fi network.
  3. Check "Remember this network" to have your Mac automatically join your home network.
Mar 03, 2014 | ASUS Us Rtn53 Dual Band Wireless Router...
What is the wireless range of the SimpliSafe base station?
The SimpliSafe base station has a wireless range of 400-500 feet.
May 09, 2013 | Home Security
We just bought an Apple Airport Extreme router. After installing the Airport Utility software, and hooking up the router, we can not configure the base station using the Airport Utility. No matter what...
First time you should connect an Ethernet cable to the AirPort, and set it up with the software it came with. Then take a note of the wireless network's name (SSID) and the password (you might want to chance them to your personal preference though), security youre using (WEP, WPA, or WPA2)
Feb 20, 2011 | Apple AirPort Extreme Base Station
Someone helped me hook up my dell laptop to the airport exteme wireless. The wireless is on the actual new laptop, but it asks for a security key. I have no idea what the security key is any ideas? ...
If your network is being created by an Apple AirPort base station, use AirPort Utility to put the base station into "manual setup" mode, then pull down the "Base Station" menu and select "Equivalent Network Password". Try the value shown there.
Oct 13, 2010 | Apple AirPort Extreme Base Station
I am trying to connect a mac to the router - need some help
. you will need the "airport " networking gear
2. If you have a base station you need to connect this to your router or modem with an Ethernet cord ( RJ45)
3. Connect the base to the MAC pc Ethernet port.
4.connect the base station power and look for the power light to go on.
5.Open MAC applications folder then the "utilities " sub folder.
6. Double click the "airport utility icon"
7. Base station on the left of the screen ( click) then choose "continue".
8. if not on the left of the screen then select "setup a new station" then click "continue .
9. enter password for the base station ( write it down) keep it . click "continue".
10. next select create and new wireless network
11. create a name for the connection
12. then select "WPA" for the security then type in a password
13Next .make a selection for either a router or modem the click "continue.
14. next select DHCP the click continue
15.Verified then click "continue" then wait for the restart of the base station.
16. You should see "congratulations" then click "quit"
Aug 13, 2010 | Dell TrueMobile 2300 Wireless Broadband...
ADDING A BUZZER TO A CHAMBERLAIN BASE STATION
I have never worked with that unit beofre, but I can take a shot. Visit your local car audio dealer, and pick up a LVT (low volatage trip)..Open up the base station, and disconnect the signal wires to the buzzer/speaker. Use those wires to feed the low voltage turn on in the LVT. THe LVT acts just like a relay, but requires much less voltage to trigger. So in theory if you use the LVT it shopuld power up your external speaker properly when the station is triggered, and is a fairly simple install.
Aug 07, 2009 | Chamberlain Wireless Perimeter Alarm
Jun 15, 2008 | Siemens Gigaset 4215 Cordless Phone
Home Security Logo
48 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
