Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart sr24h dishwasher won't get up to temp.
Our hobart is supposed to get to 180 degrees but only makes it to about 160 degrees. The incoming water temp is 120 and there should be enough pressure. Once the machine is ready to go, the water level is about half way up the screen, which seems a little low. Is there some sort of incoming water screen that is plugged or is the booster not working?
    Problem Solver:
  • 10 Answers
The water level is low (should cover the bottom of the tank about a 1/4")and the pump is starving - therefor probably not washing very well.
three things to check
1. check braided fill hose for kinks (you will have to pull the machine out if under a counter). run the machine while pulled out if possible to ensure its not kinking when you push it in.
2. pressure reducing valve-prv (if installed) on the incomming water line before the braided hose (probably under a sink). turn the screw on top clockwise to increse pressure.
TURN THE BREAKER OFF TO DO THE FOLLOWING!!
3. flow regulator (if installed) - installed under the bottom pannel at the end of the braided fill hose (about 2" long and silver). turn off water. you can simply remove it, drill out the centre or just remove the rubber peice inside.
inrease the temp by adjusting the thermostat on the right side under the bottom pannel in front of the booster.(dail is hard to see and breaker must be turned off)
remember - the machine must be turned on for several minuets to truly get up to temp.
Posted on Aug 21, 2009
I am working on a Hobart SR24H dishwasher. The cycle starts but the fill valves are not energized and no water is being allowed into the system. The hot water booster tank is heating up.
Hello Jim Richards,
I tried to pull down... any meaningful information
from the GARDEN VARIETY part houses...
It appears you can get replacement parts through grainger...
Manualslib.com does indeed show SR24H
a commercial grade unit...
(also SR24C... similar chem clean commercial grade)
Hobart SR24C Instruction Manual Page 4
Hoping to find valves, schematics & perhaps
even PART NUMBERS... (no luck).
Found some parts on the internet...
Parts list (Rev A, August 2009)
http://www.hobart.com.mx/pdf/CatPartes/F43078RevA_Lk.pdf
I don't know if you have tried to "activate" the valves
(power direct to... VALVES not responding = open coil)
Or you are having a control board failure
(test for voltage present)...
If you have power at the valves... and they are merely not responding... Some folks will tell you to clean the
(descale.... decalcify) your VALVES.
I'd say replace them... NOT CHEAP
(but it appears "KITS" might be available)
then play with the old ones at your leisure...
(obviously... if that I indeed your issue)
Grainger.com might help (but not obvious on the net)
Heritage parts, WhaleyFoodService and Partstown
(appliancepartspros was a COMPLETE BUST)
see below
https://www.bing.com/search?q=hobart+sr24h+parts&form=EDGEAR&qs=PF&cvid=dc8dfce20e70486cbcb3a4149b58c984&cc=US&setlang=en-US&PC=DCTE
Whaley
Parts Manual HOBART SR24H
Oct 12, 2017 | Hobart Dishwashers
Hobart sr24h; It is doing a double cycle; runs a compleat wash and rince cycle stops then 30 sec later start over so our normal 3 min clean now takes 7 min to fully stop operating. What could be the cause...
Thats easy....Change your timer !! The timer turns 180 degrees for one cycle .Then 180 degrees for another cycle thus completing a 360 degree rotation . One side of the timer appears to be broken.
Sep 17, 2011 | Hobart SR24-H Built-in Dishwasher
I have a LXiC Hobart dishmachine I do not want to use Sanitizer because my hot water is very hot. How do you disable the sanitizer pump and alarm? H.
Do you realize that to sanitize with hot water alone requires 180 degree F water? I am a hobart technician and I've never seen any business or residence with hot water anywhere near that. Residential hot water is generally approx. 120, Commercial locations generally use approx. 140, but never near 180 (tap water that hot would be a severe safety problem). Hobart LXIH machines use a built in booster heater to boost the temperature of the incoming hot water up to the required 180 deg.
Jul 01, 2011 | Hobart 24 in. LXIC-5 Built-in Dishwasher
My sr24h hobart undercounter dishwasher is stuck in a mode where all it does is drain water out. Will not do anything else...???
Hello There; If your unit stuck on the wash cycle and not advance to rinse cycle because the rinse water is not up to 180 degree . You've to check out the booster element and the rinse temp. I hope this will help.
Sep 19, 2010 | Hobart SR24-H Built-in Dishwasher
Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Jan 10, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I will be hooking up this dishwasher.
I'm a hobart tech.If the dishwasher is going to be a cold machine you need 140 degrees,if its a hot machine you need 180 which you need a booster.A hatco c-36 will supply the dishwasher with180-190 degrees.Any ? let me know.
Jan 15, 2009 | Hobart 29 in. AM15-1 Free-Standing...
What is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Jan 08, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Nov 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Hobart LX30H washing to hot.
what temp is it washing at. washing should not be the problem. This machine is designed to rinse at 180 degrees + to sanitize dishes. The machine could be converted to a chemical sanitize, it would use bleach in the rinse water instead of 180 degree water to sanitize.
Sep 04, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
439 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
