SOURCE: Clock which is part of
Try to reset the time by pressing the "TRIP" button.This button is located on the corner of instrument cluster. Press this button for few seconds and then you can set the correct time.Try this and see if that helps.If not then,disconnect the negative terminal of your car battery for 5 minutes then reconnect and check,if you can reset the time to its correct setting. -------------- Thanks.Helpmech.
