Question about Water Heaters
I have a Atwood 8531 when i put the thermosthat on nothing happen and yesterday everything was ok
Atwood rv furnace My rv atwood furnace won't light.It just blows cold air.
check gas if ok see if unit fan on auto if ok see if ignitor has voltage when starting
Dec 27, 2017 | Water Heaters
Atwood G16-EXT won't stay lit
check burners and orfices for cobwebs if ok check pressure
Apr 20, 2013 | Atwood G16-EXT Gas Only XT 10 Gallon DSI...
Atwood gc10a-4e only producing luke warm water
make sure bypass on back isn't open or half open then see if mixing valve on shower or outside shower off if all ok possible bad temp sensor
Feb 19, 2013 | Atwood Mobile Products Atwood 10 Gallon...
I have a 6 gallon Atwood water heater, model GCH6-7E, DSI, heater lights off on gas when swithch is placed to on position. Heats water very hot , but when switch is put in off position, flame is reduced by...
Your on right track. When this happens and small flame still there, pull wire(s) off at gas valve, or test for voltage from ECO to gas valve. No voltage, then there should be no gas. Change gas valve.
Oct 20, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Warm water, not hot , Atwood 6 gal.- burner , propane -ok
can you turn it up ... ? Maybe the burner needs cleaned ... might have spider web in the burner ... blow out with compressed air or canned air ...
May 02, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood water heater light doesnt stay on
That light in the switch should only be on momentarily while it is igniting, and then go out when everything is ok. If light stays on, it's to alert you that for some reason, the burner did not ignite, such as propane is off, or some other reason it didn't ignite. If the light stay out, then the burner should be working properly.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
