Question about Intertherm Heating & Cooling
I have a E2 EB 105 HB electric Intertherm furnace. 2004 year model It has heat strips when the blower motor comes on the heat doesn't come on. When the heat comes on the blower motor wont come on.
  • 9 more comments
  • Travis Mitchell
    Travis Mitchell Dec 12, 2016
    Where do I find the settings in the thermostat to do this
  • Thomas Woodburn
    Thomas Woodburn Dec 12, 2016
    This depends on what type of tstat you have. Download the installation and user manual for your stat. All tstats are different. Usually you have to hold 2 buttons at the same time for 3 seconds or something like that. That will take you into a different screen where you can make setting changes. Send the model number of your tstat
  • Travis Mitchell
    Thank you so much I'm on my way home but when I get home where it's at I'll send you the model number
  • Travis Mitchell
    Travis Mitchell Dec 13, 2016
    Mr. Thomas my thermostat is a Pro1516 or a pro 0 480-601-20ETP
  • Thomas Woodburn
    Thomas Woodburn Dec 13, 2016
    Not finding that but did see a pro1. Pull t stat off wall and check the back. Look for a switch that says gas/elec. Make sure you have it on electric side. Hit reset button inside the back.
  • Travis Mitchell
    Yes sir mine has that and it's on electric and I hit the reset when my temperature on the thermostat reaches the setting on heat everything is working but the blower. On the AC part of my unit everything is working properly. thermostat, blower motor, outside unit it's just
  • Travis Mitchell
    It's just on the heat side heat strips working coming on and going off properly blower motor just isn't coming on
  • Thomas Woodburn
    Turn off breaker take tstat cover off wall. Wire nut together the white, green and red wires.turn power on. This should bring heat and fan on. If it does not i would guess that the speed tap for the motor has come off of the heat relay. That may get a little complicated to explain. Let me know.
  • Travis Mitchell
    Done it still no blower motor got heat but no blower motor
  • Thomas Woodburn
    You will have to figure out wiring. Typically you have 3 wires for high voltage to your blower, 5 for low voltage (speed). Only 2 speed taps are normally used. One for the heater one for the cooling. Usually speed 4 is heat and 2 is for cooling. Refer to wiring schematic. Follow your speed wires off your blower 3 will likely be hanging loose. It may just be a bad speed tap and you can hook 5 up to the heat relay instead of 4. GOOD LUCK. TURN POWER OFF
  • Travis Mitchell
    Still not working. Thanks for all of your help Thomas if you can think of anything else I would appreciate any advice I'm going to give it up for the night though you have a good one
  • 1,711 Answers
Sounds like a problem in your tstat. In settings you need to setup where the tstat controls the fan in heat and cool.
Posted on Dec 12, 2016
SOURCE: smoke coming from furnace
You may have something (paper,dust, etc.) on the electric coils. There may also be a short in the element.
Posted on Mar 27, 2008
kf4rwe
  • 25 Answers
SOURCE: Intertherm model e3eb020h electric furnace won't start just hums
Check fuses. one may be blown, and the other one not, Therefore you are getting only 110V to a 220v circuit.
Posted on Dec 03, 2008
tborn6
  • 700 Answers
SOURCE: Furnace Blower cycles on & off
check out the fan switch on the unit and make sure that its the correct one. it should cycloe on @ 120 degrees and cycle off around 100 degrees. Someone may have put in a different one and that is not the approve one.
Posted on Dec 23, 2008
jumptrout51
  • 3361 Answers
SOURCE: I HAVE AN INTERTHERM FEB-017HAC-04 ELECTRIC
Probably a time delay relay fan switch not working.
Could be a bad low speed winding in the fan motor.
Set the wall T-stat for ON fan and see if it works.
Posted on Mar 03, 2009
HVACjake
  • 22 Answers
SOURCE: furnace dont have heat
check for pressure switch trouble or cracked ignitor.
Posted on Jan 21, 2010
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Intertherm electric furnace modular home
Will be to clean each contact-switch and scrape the contacts and use wd40 and spray of air and remove all rust, its possible that exist another options of failure.
Jun 17, 2012 | Heating & Cooling
How to replace Intertherm M1 Combustion Blower Assembly on an Intertherm M1MB 070A BW Gas Furnace Series #m1D020401209? I think this is the problem. The furnace squeals when turned on and it seems to be...
The combustion blower is easy to replace. You may be able to prolong the life of the motor by applying lubrication to the shaft bearings. If the motor is too far gone then replacing it is the only option. Just remove the screws that mount the blower case to the heater, disconnect the wires and reverse the steps to install a new motor.
May 04, 2017 | Heating & Cooling
My intertherm furnace (old model) has recently getting quite loud and clunky during its heating cycles, sound like the blower maybe??
Your blower motor has several speeds to it and by the problem you are having it sounds as though the blower motor may be going out. The motor has a slower speed for the heating cycle and since you have the noise in the heating mode I suggest having the blower motor changed as soon as possible since it could cause other problems in the heating section of the furnace( possibly burning out the high limit switches). Good Luck on your repairs hope this helped
Dave
Oct 20, 2009 | Intertherm P3RA-048K Air Conditioner
Blower will not come on
could be the fan relay is bad. or the run capacitor. if these check good. you may have a bad heat sequencer. hard to tell, if you thave a/c you can turn thermostat fan swith to on and if blower comes on then relay and capacitor should be ok. some units have two or three heat sequencers 1 controls fan and the others control heat strips hopefully this helps good luck
Jan 04, 2009 | Kitchen Appliances - Others
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
