Question about Kitchen Ranges
I bought an Insta Flame model FSDV 30 direct vent wall furnace, need a natural gas conversion kit. It currently is set up for propane and could use some help in finding the parts and installing them.
  • Andrew Taylor
    Andrew Taylor Dec 11, 2016
    What you should do
    Consumers should immediately stop using these fireplaces.
    Any affected fireplaces currently in use should have the fuel supply disconnected immediately. The manufacturer is no longer in business and there is no retro fit kit available. Contact a licensed gas technician for disconnection.
  • Kitchen Ranges Master
  • 18,239 Answers
There is a ban on that particular furnace as they can explode!
You won't find parts or anyone that will work on it.
[PDF]TSSA Bans Series of Insta-Flame and Northern Flame Fireplaces
  1. Cached
  2. Similar
Oct 23, 2012 - (TSSA) has banned a series of natural gas and propane-fired direct vent ... 'FSDV22' or 'FSDV30' or 'FSDV32' in the model name or number.
TSSA Bans Series of Insta-Flame and Northern Flame ... - CNW Group
  1. Cached
  2. Similar
Oct 23, 2012 - All Insta-Flame and Northern Flame natural gas or propane-fired direct vent freestanding fireplaces with 'FSDV22' or 'FSDV30' or 'FSDV32' in ...
[PDF]Fuels Safety Program DIRECTOR'S ORDER - TSSA
  1. Cached
  2. Similar
Mar 25, 2016 - Natural Gas Fired Direct Vent Free Standing Fireplace - Model ... Insta-flame or Northern Flame: Models FSDV22, FSDV30, FSDV32, D222.
Majestic Fireplace - - Recalls & alerts - Healthy Canadians Website
  1. Cached
  2. Similar
Nov 9, 2012 - Natural gas and propane-fired direct vent free-standing fireplaces ... Insta-flame or Northern Flame (Models FSDV22, FSDV30 and FSDV32, ...
TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32
  1. Cached
  2. Similar
Dec 21, 2012 - TSSA Safety Order Ban of Majestic FSDV22, FSDV30 and FSDV32 ... CFM Inc. (Majestic Fireplace) and bear the trade names Insta-Flame or Northern Flame ... (a) Natural Gas Fired Direct Vent Free Standing Fireplace - Model FSDV22, FSDV30 ... -Stove shipped as natural gas; LP Conversion Kit included
Posted on Dec 11, 2016
  • Andrew Taylor
    What you should do
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
Jan 12, 2016 | Heating & Cooling
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Why does new furnance with propane conversion have yellow flames?
Make sure the kit included smaller sized orifice's and spring kit for the gas valve. The number on each orifice should be cross referenced with total btu's rating of the furnace. It does seem like there is too much fuel or not enough air intake (combustion air). The inches of W.C. seem fine, but you still may be getting too much volume of fuel with too large of sized orifice's. Hope that helps
Dec 20, 2013 | Heating & Cooling
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
I have an empire wall heater that was converted to natural gas how do i convert it back to propane?
you will need a propane conversion kit designed for that particular model heater.
which would most likely consist of a heavier spring for the gas valve and orifices for the burners depending on how many burners you have.
Most all gas heaters come thru the factory set up for natural gas and most have a kit available for conversion to LP (Propane) You will also need a manometer or a gas pressure tester to check the incoming and outgoing pressures from the green (2ndary )regulator outside your house to the gas valve inlet side,usually 11 to 14" WC( water column) pressure( static) 14" being MAX!!
Outlet pressure with burners running 10-11" WC approx. This info should come with the conversion kit if available. If you are not comfortable working with gas then find someone who is, for safety reasons.
Jan 31, 2010 | Reddy Heater RLP100 Portable Forced Air...
How to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
I bought a used direct vent vermont castings radiance model 2600 set up for natgas. I have been trying to get it converted to propane, with no luck. All dealers are telling me that the conversion kit is no...
if you know a lot about it you could convert it your need to get rid of the Propane need a Natural Gas Valve and you need to change the orifices....should be stamped on the rating plate the size of orifice for natural gas....I wouldn't recommend you do it yourself unless you have a license....or as I said know a lot about it...I wouldn't have a problem doing it in my own house...however you run into Insurance implications should anything happen if it's not an approved kit from the mfg.
Oct 19, 2009 | Heating & Cooling
I have a whirlpool gas oven Model sf385peew 0 and iam changing it from gas to propane how do you adjust the flame and also do we have to do anything to the stove we bought the conversion kit but it dont...
turn the gass off
find the gas valve on the back wall
unscrew the top
and replace the top with the part from the kit
if you have orrifices you will need to replace those
they go straight down the center of the burner
Oct 03, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Changing from natural gas to lp.
By getting a gas license! LOL
Remember to tip your waitress! I'll be here all week - Goodnight! it out of my we go:
1. Find out if a conversion kit exists. Answer: Yes it fact it came with it originally. If it had me doing the install, I would have taped the kit to the back of the range.
....and I quote, "IMPORTANT: Your cooktop is factory-set for use with natural gas. If you wish to use L.P. Gas, an L.P. Gas Conversion Kit is included with your new range. Models with the TripleTier Flame Burner will include a TripleTier L.P. Gas Conversion Kit and a kit for standard ranges. See “Installation Instructions” for details on making this conversion.
2. Obtain the kit. This is more difficult than actually doing the conversion. Unless you have a dealer nearby, I'd simply call Kitchenaid directly: (1.800.461.5681) They will either send it to you directly (quite possibly for FREE) or point you in the right direction.
3. The kit will come with instructions, but briefly, here's what you're getting into: The kit will consist of 1-3 orifices. These will reduce the amount of flow going to the burner(s).
Why? Two reasons: a) Propane burns hotter and b) Propane moves quicker than N.G.
You might need: Allan Keys, Screwdrivers, Channel Locks, Adjustable Wrench.
You'll just disassemble the manifold, install the orifice(s), and GO!
Good Luck.
Sep 08, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
Jan 31, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Kitchen Ranges Logo
174 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
