Washer won't drain .. checked the filter and pulled a bunch of change out of it but it still won't drain .. any ideas ?
    New Friend:
Does filter need emptying?Or do you have tissue blocking outlet pipe?
Posted on Dec 11, 2016
  • 42 Answers
the filter is located right after you open the drain cover on the bottom of the washer it's a hard plastic filter, if it is not clogged with any debris, then it sounds like your pump motor is bad, maybe need to replace it. lg's are very sensitive........., find out the part number and search it through google. if not email me and i could set sumthin up for you.
Posted on Dec 12, 2008
  • 5 Answers
SOURCE: Samsung WF448AAP chimed and read to check filter.
I would believe that the water pump has given out. If it is going thru the spin cycle after you drain the tub of water it is almost certainly the pump.
Posted on Nov 12, 2010
  • 86 Answers
SOURCE: Maytag heavy duty super capacity
It is a computer problem. My daughters machine did the same thing and the company came out and replaced the computer board and it fixed the problem.
Posted on Jul 16, 2011
SOURCE: We pulled our stacked washer
Hi, I got a samsung WA85B5 washing machine running for nine years already, but last week the electronic mulfunction in such a way that when the power plug is turn on, the electronic turned on automatically without pressing the 'power' button and non of the button on the panel works. I installed a new circuit board today but ends up a different problem. After I plug in the power I press the 'power' button and the LEDs light up, all the other buttons function properly ( delay timer, water level, function,course) except the 'start' button. After setting everything it refuse to start. Please help. Thanks in advance. Yip
Posted on Sep 19, 2011
  • 8220 Answers
SOURCE: i have a roper washer 5 years old and it won't drain or turn on now it was working fine yesterday ive unplugged replugged pulled out all the clothes checked power supply and hoses what now?
I looked up your model number. You particular machine allows for wash with the lid open. You nothing happens. On that case I would check the motor capacitor.
Posted on Nov 13, 2011
I have Kenmore110 digital washer,it won't drain or
Plug off the mains from the wall. Take out the exit hose from behind washer to floor level to drain out excess water. Raise up your washer slightly or feel for 3 screws right under the front, bottom. Unscrew these and pull down - you will find the lint trap and filter. (You may find a hose capped here for excess water, if not -as above for excess water) Be prepared for water. Clean out and refit. See that the exit hose is fitted at correct level after the job. Your filter and pump shd be checked according to your usage.
If helped pl click so.
Apr 22, 2013 | Washing Machines
Drain water
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My washer wont drain the water how do i fix it
I had this problem. It is b/c the drain is cloaged with possibly a bunch of change and what not. You have to take panel off at bottom of washer and then there is a try that you pull out and it will probably be filled with whatever has come out of pant pockets. Clean it out and your water will drain just fine.
Dec 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Samsung WF448AAP chimed and read to check filter. I drained the water out and cleaned the fillter. It had 2 quarters and a bunch of junk. I cleaned it and restarted machine and the washer starts of...
Nov 12, 2010 | Samsung WF448AAP Front Load Washer
code f-2 indicates a long drain or pump issue. chances are you pump is clogged. remove the lower panel on the front of the washer by removing the 3 screws under the panel. once that is out of your way you will see the pump right in the middle. you will also notice that the pump has a removable filter in it.
first go get a mop bucket to catch the water. remove the single screw in the front pump support(if it has one) and then pull the pump forward some so it will hang out the washer just enough to reach the bucket. loosen and remove the filter piece slowly to allow water to drain out. also dont pull the filter to far out yet just incase you have to close it back up if the bucket gets too full.
once that filter is out you will probably find baby socks, lingerie, or just a bunch of change clogging the pump area. if you cant see any thing in there then you will need a new pump.
look up your washer by the model number here and order a new pump, probably around $100
Lebarchrigen Appliance Repair
Dec 10, 2009 | Whirlpool GHW9100L Front Load Washer
Kenmore Elite Frontload washer
Dea, F02 is the code for long drain. Your filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. See if the washer comes back to back
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
