Question about Coffee Makers & Espresso Machines
My jura c9 impressa coffee machine is not frothing the milk. It will work for about 5 seconds then only steams. I always put clean water through cuppachino after use what could be the problem
SOURCE: frothing tube
It sounds like the tube is clogged.  Remove the silver tip on the bottom of the tube.  Hold it up to the light and see if you can see through it.  If you can not, take a tooth pick and clean the tip out.  This seems to have worked for mine.
Posted on Oct 24, 2007
  • 515 Answers
SOURCE: Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Posted on Jul 11, 2008
SOURCE: Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Posted on Aug 12, 2009
  • 39 Answers
SOURCE: frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Posted on Dec 31, 2009
SOURCE: Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
Posted on Mar 30, 2010
Jura impressa Z5 doesn't switch on anymore. A few days before just was displaying "maintenance" and then no more signs of life.
Search Results
    How to Fix Jura Z5, Z6 and Z7 - YouTube
    ? 16:03
    Aug 18, 2013 - Uploaded by Parts Guru
    I changed the filter, pressing button for System Fill, get message System is filling. .... My Jura Capresso Z5's milk frother doesn'twork. When I ...
    Jura Capresso Z5 Impressa - No milk frothing - YouTube
    ? 1:05
    Oct 25, 2013 - Uploaded by Frederic Valiquette
    Hi all, My Jura Capresso Z5 Impressa is acting up. The milk frother doesn't work anymore. When I ...
    [PDF]Instructions for Use, Manual JURA IMPRESSA Z5 - Esperanza
    The IMPRESSA Z5 - Generation II Manual. The 'IMPRESSA .... 5 Preparation at the touch of a button. 40 ..... As coffee and coffee specialities are very important to JURA, we have compiled a ...... It doesn't matter whether whole milk or skim.
    My Jura Impressa Xs90 won't switch on and nothing is - Fixya
Jan 31, 2016 | Coffee Makers & Espresso Machines
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Oct 19, 2012 | Jura Capresso Impressa S90 Espresso...
Jura impressa X7 will no longer pull cleaning fluid, dispense milk or steam
I would like to know more in order to better understand. When any of the steam functions are selected do any errors display? Also, does steam come up through the machine from inside? It could also be that a solenoid valve (electronic valve that can operate flow) may be bad. It almost sounds like the problem you have may be coincidental with the hose incident and now it's a little harder to diagnose.
Apr 10, 2012 | Jura Capresso Impressa X7 Espresso Machine
My jura impressa z5 is having trouble foaming the milk...worked fine last season but we can't seem to get it foaming the same as it was before...suggestions??
The common cause is that the frothing connection is faulty. You can look at the Guide to clean the Jura frothing connection, or try this. Take some bicarb or vinegar, dissolve in 400ml luke warm water, select cappuccino maintenance under the options, or press the milk button. Run the complete mixture through then. Run about 600ml of plain water through the spout. Turn the sport from froth to milk and back every 10 seconds.
If this does not work, then there may be a need to decal the machine.
Jan 24, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
I have an Impressa Z5 and it won't **** milk up the tube as either part of the cappucino program or the stand alone milk program. I've checked and nothing in the nozzle is blocked and the plastic pipe...
There are three possible causes to milk not frothing: 1. The frothing tap is blocked: to unblock either use the cappuccino cleaner from Jura, or in 400ml of luke warm water dissolve a teaspoon of vinegar or 1/2 teaspoon of bicarb and run this liquid through the frother until completely finished (or run the cleaning program). The run about 600-800ml of water through the system. While passing the liquid through let the tap rest at froth, and milk setting for 5 seconds at a time. Repeat if necessary. To prevent this in future clean frother after 5 minute of none use. 2. The breathing nozzle is blocked, you can use the Jura Maintenance guide to see how to disassemble and clean and reassemble, but most Juras come with a spare, so replace it. 3. The machine needs to be descaled, since there is lime or scale in it.
Jan 15, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Steam and froth malfunction
The milk can not be room temperature.  It needs to be cool, does not have to be fridge temperature but can not be warmer than room temperature
Feb 18, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Nov 05, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
