Hello I don't have remote control but trying to figure out how To factory reset
  • Televison & ... Master
  • 18,239 Answers
There is no factory reset on a Standard CRT tube television (the category you posted to), just a Degausse button.
One a Flat Screen television it is in Menu settings at the bottom of Setup.
You can only do basic controls from the television, you NEED a remote.
Posted on Dec 11, 2016
Toshiba backlight problems?
Without a remote control, you can't enter its service mode to unlock it. Try to get an original remote control. Contact the authorized service center.
Jul 01, 2013 | Televison & Video
I have a Pioneervsx-1021k AV Receiver and all the buttons were working fine until I decided to play with the remote. Now some of the buttons light up, and some don't. I have found that not being able...
Just reset the system and try. So many external commands may confuse the system control IC inside, will hang up very like our computer systmes do. Resetting it to factory settings will make the unit work well. To reset the system:
Disconnect the iPod and USB memory
device from the receiver beforehand
1# Switch the receiver into standby.
2# While holding down ENTER on the front
panel, press STANDBY/ON.
The display shows RESET .
3# Select 'RESET' using PRESET then
press ENTER on the front panel.
The display shows RESET? OK.
4# Press ENTER to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory default settings.
Note that all settings will be saved, even if
the receiver is unplugged.
If this process does not help you, your system needs service with its main system control circuit. Actually this is a very skilled job, and should be done either by any well experienced service technician or by the Authorised Service Center for Pioneer at your town. OK.
Aug 21, 2011 | Pioneer VSX1020K Receiver
All of the sudden the remote control does nothing, won't work at all. What can I do?
try to remove the batteries from remote, if that don't work, unplug main unit from wall for 40 Min., and it will reset back to normal.
Jun 09, 2011 | Bose Audio Players & Recorders
My remote stopped working can it be reset
I found the following reference to resetting anything related to the ZN110 remote:
"This remote control works well for all the basic functions on the television: changing channels, adjusting volume, and turning the set on and off. There is not a way to program the TV with the remote control, so if you need to reset the channels after a power outage, for example, you have to do it manually on the TV set itself."
Or it could just be batteries?
Feb 26, 2011 | Zenith ZN110 Remote Control
I can't figure out how to get my Sony KV-34HS420 to factory settings!
To reset your tv to factory settings do the following:
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
4 Release RESET.
Jan 23, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Trying to reset the settings for my toshiba model27a45
It is easy to reset your Toshiba set to factory defaults. Enter each options, ie, picutre, sound etc, and press "Reset" button on your remote control to reset each options to factory settings. The default factory settings for Video is DVD. Ok.
Jan 07, 2011 | Toshiba 27A45 27" TV
None of the video inputs are working but the audio is fine.
You just make all vidieo input options to factory setting and try.
To get it follow this.
Press the MENU button.
The main menu appears
Surf through and select the Video Menu
To select the Vodeo Menu DISPLAY==>HILIGHT==>SEELCT
To restore factory settings :- Press reset on the remote control while the Vido Menu is selected. To restore each Mode to factory settings press reset after selecting the mode to be reset.
Dec 09, 2010 | Sony KP-48V90 TV
Enter admin mode
I have 10 unit that belonged to Chase back, and it tries to auto connects to there DNS. I tring to reset the unit to factory default with out any success. I have tried just about everything. The remote connect flash don't work because it boot into auto connect with CHASE logo, then fails finding DNS screen. I was able to access the bios, and get into the control panel. I still looking for a way to reset to factory default without success. G, Control+G, Fi report has been used to gain access, but can't change the boot process from logging as CHASE with the auto connect. If you have a solution......
Nov 13, 2010 | WYSE Winterm S30 Network Terminal
Our TrueTech TV remote came with a preset factory code that allows us to override our code in case we forget it. Unfortunately, my billiant children have figured out the factory code and are now able to...
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Jul 27, 2009 | TruTech PLV16190 Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
