Question about Yamaha HTR-3063
I bought a used Yamaha HTR-3063 without a remote. Every time I turn it on, it tries to start the YPAO process. Is there a way to turn this setup option off?
SOURCE: yamaha htr-5830
I own this receiver, and 18db is damn loud. Granted - your room might be significantly larger than mine with your speakers spread much further apart, or your speakers might be much less efficient than mine (this means that they want more power than the receiver can dish out - I have whatever speakers came with the "YAMAHA Home Theater in a Box" [the model that came with the HTR-5830]), but I'm pretty sure that the receiver doesn't get any louder (or at least not much). My suggestion is to turn down the volume to about -20db and work up from there after the movie has started. It might be easier to test the volume using music. The negative sign is deceiving - I rarely bring mine up to 0db. Also check the resistance - there's a red switch on the back of the receiver that switches between 6 and 8 ohms - make sure that it matches your speakers' resistance. If turning down the volume doesn't work, then post the problem again. Hope This Helps.
Posted on Nov 07, 2006
  • 319 Answers
SOURCE: remote code
This can be a frustrating process! I have had similar problems in the past, but perseverance is key!
Please be sure that you did all of these tricks:
1 Be sure to press and HOLD down the appropriate input button while pressing the AV power button for 3 full seconds.
2 Enter the code. Unfortunately, you may have to try all of the codes listed for your manufacturer. There are 23 for Phillips! There are "only" 8 for RCA, so you might try that compnent first.
It sounds like you are doing the right things, but is it possible that you are accidentally hitting a wrong button during the process? ie; using the TV power button instead of the AV power button? After completion of the task, are you then hitting the proper component button, such as DVD before trying to use the remote to control that device?
I apologize if you have tried all of these things, but I am not sure of your level of expertise! Good Luck!
Posted on Jan 01, 2008
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
  • 6 Answers
SOURCE: cable company remote cannot find Yamaha HTR-6130
this one worked for me...well...sort of, no power, but it got the big one! VOLUME! 0176 and to clarify this is to reply to houseof5girl, this worked on a motorola dvr from cox.
Posted on Jan 23, 2009
  • 1114 Answers
SOURCE: trying to program my Receiver, a Yamaha HTR 6130 to the AUX on my Comcast remote, but neither of the codes they gave me seem to be working.
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
Posted on May 24, 2009
How to fix a wobbly Volume knob on the Yamaha HTR-3063 AV Receiver?
it called a potenciometer find the number of it and replace just that part
Aug 06, 2014 | Yamaha Htr 3063 5.1 Channel Receiver Hdmi...
Yamaha HTR-5990 Audio no longer works
Sorry Michael, you have a problem in the audio amp section of the receiver and unless you know how to troubleshoot solid state electronics, you will need to have this unit serviced by a pro. Good Luck
Jun 21, 2007 | Yamaha HTR-5990 Receiver
My HTR 3063 is not producing any sound
The YPAO isn't on the 3063 model. only 4063 and up. If this is used and you can't get your money back, there is a firmware file here that can help get your receiver running correctly.
Apr 28, 2013 | Yamaha HTR-3063
No picture using my playstation 3 with my yamaha receiver htr 3063
you might have to reset the video output. hold down the power button for 5 seconds. It should beep and the iight will flash. wait a few seconds then turn it on.
Nov 16, 2011 | Yamaha HTR-3063
Speakers wont work on the htr-3063....worked 10 minutes before on the old receiver
check to see what ohm your speakers are using. I know the 3063 supports both 6 and 8 ohm but it is defaulted at 8.
Aug 16, 2011 | Yamaha HTR-3063
How do I connect a CD player to my Yamaha HTR-3063 receiver?
... in whatever manner it requires according to its manual. The Yam accepts just about anything.
Aug 14, 2011 | Yamaha HTR-3063
Where can i get firmware download for yamaha htr-3063
Hi al_sha,
Please be informed that Yamaha did not release firmware that can be downloaded by users, however they provided a step by step procedure on how to update the version of your unit. Please visit this link to have the Firmware update procedure for Yamaha HTR-3063.
Hope it helps.
Thank you for using FixYa.
Jun 16, 2011 | Yamaha HTR-3063
On my HTR-3063, I could not get it to come on. So, I unplugged all the cables and speaker wires, and I plugged it in without any plugs or wires, and it turned on. So I changed all my wires and HDMI cables,...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Add things one at a time until you identify the one component (probably a speaker) that is causing the problem.
Mar 22, 2011 | Yamaha HTR-3063
How to solve a W 1 error on a Yamaha HTR-3063
Are we really talking about a HTR-3063?
Register and download the manual for free at
Strangely enough, that message is NOT documented in the HTR-3063 manual, but in another Yamaha manual (HTR-5063) it means the speaker being tested is believed to be Out of Phase, meaning wired incorrectly.
Your unit (HTR-3063) doesn
Feb 15, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I have YPAO showing on my display and I can't get a picture on my tv. Do you know what YPAO means?
The receiver is in "Setup" mode and wants the microphone plugged in for testing sound parameters. Press "menu" on the remote, this will exit the mode. If you still have an issue, post a comment and I can help you some more.
Aug 04, 2009 | Yamaha HTR-5990 Receiver
Yamaha HTR-3063 Logo
41 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
