Question about Coffee Makers & Espresso Machines
I need to know which part I need for a K1301 110 cup urn?
Urn perks the coffee, but then gets cold. Not totally cold, but not as hot as it use to keep the coffee. I assume that the element is OK, but the warming thermostat seems to .be bad
3 Suggested Answers
  • 33 Answers
SOURCE: cofee perks okay, does not stay warm.
http://www.abtecparts.com/westbend.htm
Try this to order all of your part needs!
Posted on Feb 16, 2009
espressonist
  • 1711 Answers
SOURCE: 55 cup farberware coffee urn.
A burn out element it means the two ends with the ohm meter should read infinity number or nothing depents from ohm meter in any case you should read that the two ends are open circuit somewhere the internal wire is cut off. As for the thermostat you should conect the two points where the lement is conected and turn the thermostat if you seen at onhmeter that aroud room temperature the themostat open and then if you rotate it reverse just litle bit and the theremostat close then the thermostat works fine. Youcan even here and small click when it open and close during the turning left and then right at the point of room temeperature.
Good luck.
Remember top vote for this answer
Posted on Mar 10, 2010
The pot perks but its just hot water when finished
You need a keepwarm element. Go to repairshack.com. Good luck. Ron
Sep 29, 2012 | Faberware 12-55 Cup Coffee Urn
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
Coffee is not hot. Only about 100 degrees.
Hi. If it perks it is not the main element, it is the keep warm element, it is very instrumental in perking. Water should be about 170 to 190 they all differ a bit. Go to repairshack.com. Good luck. Ron
Feb 12, 2010 | Faberware 12-55 Cup Coffee Urn
I broke the pump tube for my Farberware Urn #155-A, 55 Cup. Does anyone have one?
New tubes are available from Goodman's, 10914 NW 33rd Suite 107, Miami, FL 33172. Tele: 305 278 8822. If you broke just the ceramic outer tube, it will still work alright. The purpose of that cermaic tube was to prevent the hot water being perked up the stem from heating the other water that hasn't been perked yet.....
Jan 17, 2010 | Faberware 12-55 Cup Coffee Urn
Farberware 155C Urn coffee maker, light is on when plugged in
Hi. There are a few things that can be broken. Take the bottom off and see if you can find the problem. Good luck bobbyone
Jan 01, 2010 | Faberware 10-22 Cup Coffee Urn
My 25cup Farberware urn quit perking coffee can it be reasonbly repaired?
I have the same urn and had the same problem.
There are 3 common causes of lost perk that can be dealt with at home, and cause about 1/2 of the failures with these urns. They are very common when the pots are used rarely or carelessly cleaned after use, and when coffee is ground too fine for perc (drip grind is too fine for perc). As long as the pot is still heating, check these three things:
1) Clean the _inside_ of the hollow stem )that holds the basket and moves the water from the bottom of the pot to the top), to remove all grounds. You should be able to see clearly through it.
2) At the bottom of this stem there is a very small cup that has little holes in it and fits into the little well at the bottom of the pot. Make sure these are completely clear.
3) Scour out the little well so all residue/ grounds are removed and the little cup fits perfectly into the well.
It is the perfect fit of the two that allows the perc-ing cycle to occur.
If the pot is not heating, or these cleaning measures do not work, a local electric repair shop can probably do the repair for about 1/2 the cost of a new urn.
Dec 04, 2009 | Faberware 12-55 Cup Coffee Urn
10-22 urn
If you have the L1350/155C, the manual states 1-1/4 cups coffee for 12 (5 oz) cups, for 30 cups use 3 cups coffee using standard measuring cups. Take the stem & filter out when the coffee has finished brewing so the bitter oils do not get into the coffee.
Dec 17, 2008 | Faberware 10-22 Cup Coffee Urn
Coffee urn heating element not working
there are 3 or 4 componants inside that could cause the problem.
if you can use an ohm meter, check all of them for continuity.
a switch
overtemp fuse
perk control fuse, or keep warm fuse
element
all should read "short " or almost 0 ohms when the unit is unplugged '
Dec 14, 2008 | Faberware 12-55 Cup Coffee Urn
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
