Question about Panasonic Televison & Video
My Panasonic viera wont connect to on demand saying it needs to be connected to the internet but when i check it says i am connected?
  • 4 Answers
SOURCE: panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Posted on Dec 30, 2008
SOURCE: Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Posted on Jan 05, 2009
  • 222 Answers
SOURCE: how to connect sound bar
Does your TV have an Audio out? If it does then you can connect it from there.
Posted on Jun 12, 2010
TV #1
  • 129 Answers
SOURCE: I connected my 65 inch panasonic viera tv to my
If you are conected VGA cable set your TV to PC input. When you turn your laptop press fn then
f8 that should transfer the signal to the LCD.
Thank you
Posted on Dec 12, 2010
  • 1285 Answers
SOURCE: I wan to connect my panasonic 42" viera HDTV to my
you need a VGA adapter (connect to laptop) to Mini D-sub 15-pin x 1 (side) so this will plug into TV.. you can use a mini cable (again for laptop to TV) for audio.... once connected go to laptop display Intel graphics to split the video signal between laptop/TV or just TV... note the laptop will go blank if you don't want it split....and the TV will go blank if it do not seek a signal from the laptop..(just preparing you ... this is normal).. if this do happen unplug the adapter for 5-10 seconds from TV... now you can look at movies, photos and even have your spreadsheets on a larger screen..
season greetings
Posted on Dec 20, 2010
How do I fix my proxy setting
Do you need to setup a proxy for any other device on your local internet connection? Normally you do not and the TV should connect just fine. Are you using WiFi or cable to connect the TV? For fastest connection I would use a cable.
Mar 07, 2015 | Panasonic VIERA Televison & Video
I cant connect to the internet I have the cable going directly into the TV and I still cant connect to the TV can someone tell my why?
It is sad to say that Panasonic - 50" Model: TC-P50U50
lacks the ability to connect to internet.
It should have an Ethernet port.
Sep 29, 2012 | Panasonic Viera TCP50U50 50-inch Plasma TV
Panasonic viera tv. Connection error 007
My TV set is PANASONIC VIERA 32AS600 series. Received error 007, canot connect to wi-fi network. In wi-fi settings, change to MANUAL, check proxy settings: delete all letters/characters in proxy address (leave blank), proxy port is not critical. Check your connection. Good luck !
Jul 30, 2012 | Panasonic Televison & Video
When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006. How do I...
Viera has a set-top box in the TV and the lan wifi router can be connected to cable plant for internet. TV can also send out programs on the set-top box to other wifi receivers. Error code 006 is server failed, Panasonic had a fix on jan11, 2012.
Feb 11, 2012 | Computers & Internet
Wifi i have a wifi modem can i use the wifi without connecting it to the tv or what do i need to use to get internet connection on my new panasonic viera plasma?
Yes,Wifi internet signal dose not require any connection to the tv all.Read ur tv owner manual how to activate ur tv Wifi internet signal out that all.This tv it is a internet ready compatible tv wright?
Jun 11, 2011 | Panasonic 50 TCP50X3 50 Plasma TV
I have a desktop HP connected to internet Broadband service via a "2wire" router thru my Windstream phone account. I have a Dell laptop that I'm able to use with the wireless connection...
you wont see the pc screen on the tv if that is what your expecting, if the tv is capable of receiving netflix then it will pick that up seperately from the pc, it will only need a wireless connection to access the broadband, you will also need a valid subscription to the netflix service. The fact you have proved you have a valid wireless connection means its connected. There will be an options button to select the internet content to view on viera cast
quote from panasonic ---
VIERA Cast's assorted online content just keeps getting better - in addition to the popular contents such as YouTube and Picasa Web Albums, it now offers Pandora Internet Radio, movies streamed from Netflix*, exciting sports from FOX Sports, tweeting web communications with Twitter, and even home video and audio conferencing with Skype. It also provides USB terminals for a keyboard and Wireless LAN Adaptor. No PC required. Skype function requires an optional communication camera TY-CC10.
Skype service will be available late June 2010.
*Netflix unlimited membership required. Service on Viera Cast TV will be available summer 2010.
*Keyboard and Wireless LAN Adaptor are not included.
Apr 17, 2011 | Panasonic Computers & Internet
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Dec 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Televison & Video Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
