Question about Vizio Televison & Video
How do I repair a Vizio P652ui-B2 HDTV that has an all white screen shortly after boot up? Vaguely can make out menus and apps.
I have a Vizio P652ui-B2 that now displays a white screen after boot up. Though it starts gray it quickly turns white with vertical bars. It's nearly pure white though I can vaguely see the menus underneath but not enough to make out much more than the Netflix logo, etc. Serial begins LWZAR. Purchased from Best Buy in early 2015. This is the 4K model.
eagle338
  • 4889 Answers
SOURCE: the screen has lost its brightness
Someone has probably changed the brightness settings. Increase the brightness and see if this resolves the issue. If it does not then I would assume that the monitor's backlight is a toast and you may have to install a new backlight.
Posted on Feb 15, 2009
Geekman
  • 32281 Answers
SOURCE: I'm also experiencing same sort of white screen problem.
To determine if the LCD screen or the video card is faulty, connect an external monitor to the video connector on the laptop. Power up the external monitor first and then the laptop. The video should divert automatically to the external monitor and if you get a normal image then the video card is OK and the fault could be the LCD screen or the video cable. Reseating the video cable and connector on the motherboard could fix yout problem.
Posted on Jun 14, 2009
kd6rhd56
  • 400 Answers
SOURCE: Solid white screen on my laptop
sounds like the on-board video card is dying/ or the screen is dying too
Posted on Jul 10, 2009
Joed911
  • 4338 Answers
SOURCE: Just purchased a Vizio 37" HDTV with Netflix app
The Vizio does not have Internet capabilities. You need to hook up a computer via the VGA or HDMI port. Then youor computer controls what you do with the intenet.
Posted on Dec 03, 2010
  • 59 Answers
SOURCE: Gray vertical bars on screen but no picture
It sounds like you might have shorted out the display panel driver board / boards.
These boards are located at the bottom of the screen and are prone to liquid damage.
Just before this happened, did you happen to spill something on the screen or clean the screen using a spray bottle cleaner?
The only fix I know of is to replace the whole panel but it is usually just as cheap to buy a new TV.
Posted on Nov 28, 2013
Testimonial: "Thank you, Ken. It is quite possible it was sprayed with a cleaner to clean the screen."
I have a Vizio TV Model P652ui-B2. A few days ago started to go off and on for a short time but around every 10 or 20 minutes sometimes longer, but it comes right on again.
The tv has most likely filled upi with dust on the inside. This will cause it to overheat and shut down. When it cools it comes back on. the only way to fix this is to get the dust out of the inside. Make sure all the vent holes around the outside case are not blocked by dust. The only way to get the dust out of the inside is to have a qualified person open the case and blow the dust out.
May 03, 2017 | Vizio Televison & Video
Tv shuts off by itself - Vizio 40 Inch LED Smart TV E400I-B2 HDTV
The cause of this is a shorted circuit board, as to which one that will take testing.
Dec 02, 2016 | Vizio Televison & Video
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Hi I have e422va Vizio TV when I plug power coward only front light is turn white no led screen is black can you please help
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 15, 2015 | Vizio E422va 42-inch Lcd 1080p Hdtv With...
What might be the problem on my Vizio XVT373SV HDTV that will not turn off and on properly?
Jun 29, 2015 | Vizio XVT373SV 37" 1080p 120Hz Edge Lit...
Vizio m470nv will not come on, logo blinks orange to white.
It may not be the caps at all, a lot of the new LED Back-Lit TV have faulty LEDs. They short and pull down the power supply, and to a novice it will seem like a bad power supply. That means that you must replace the bad LED's in that particular LED strip before you can fix the problem. Not an easy repair for a rookie.
Mar 03, 2012 | Vizio M470NV 47 in. LCD HDTV
Vizio L32 picture too dark
Bring it back as you can't get parts for Vizio.
Jun 06, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
29 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
