Question about Air Tools & Compressors
I'm put inlet & exhaust plates in and the old 1's are busted all up and I can't see where they go, can u help me with that and the head bolts torque spec. In a Makita 5200 air compressor.
  • 25 Answers
SOURCE: 87 samurai bolt torque specs for engine
The haynes book is not recommended since there are numerous mistakes and they still will not update. One of the biggest is the firing order.
The factory service manual is the only way to go.
Head bolts - 46 - 50.5 lbs (there is an order sequence for the bolts)
Intake & exhuast manifolds- 13.5 - 20 lbs
Flywheel - 41.5 - 47 lbs
Clutch cover - 13.5 - 20 lbs
Posted on Mar 17, 2009
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
polarcycle
  • 1392 Answers
SOURCE: head bolt torque spec
Always use new head bolts.
1)tighten to 40ft/lbs
2)back off 1/2 turn
3)tighten back to 40ft/lbs
4)tighten an additional 90 degrees
5)tighten an additional 90 degrees.
Posted on Aug 16, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
  • 12 Answers
SOURCE: head bolt torque specs for 200 honda accord 3.0
its a three step process 1st 29ft/lbs 2nd 51ft/lbs 3rd 72.3ft/lbs
Posted on Apr 25, 2010
What the torque settling on a 1.8spi vauxhall cavalier 1994
Cylinder head Renew bolts: Yes Tighten: 25 Nm Tighten: 90° Tighten: 90° Tighten: 90° Other engine tightening torques Main bearings Renew bolts/nuts: Yes Main bearings Stage 1: 50 Nm Main bearings Stage 2: 45°-60° Big end bearings Renew bolts/nuts: Yes Big end bearings Stage 1: 35 Nm Big end bearings Stage 2: 45°-60° Oil pump to cylinder block : 6 Nm Sump bolts : 15 Nm Sump drain bolt : 55 Nm Flywheel/driveplate :
  • Use new bolts and tighten as follows:
      • 1,4/1,6 = 35 Nm + 30° + 15°
      • 1,8/2,0 = 65 Nm + 30° + 15°
  • "Pot"-type flywheel = 65 Nm + 30° + 15°
  • Tighten drive plate to 60 Nm.
Clutch pressure plate : 15 Nm Crankshaft pulley/damper centre bolt : Use new bolts. Tighten centre bolt to 130 Nm + 40°-50°
Camshaft sprocket/gear : 45 Nm Camshaft/rocker cover : 8 Nm Inlet manifold to cylinder head : 22 Nm Exhaust manifold to cylinder head : 22 Nm Spark plugs : 25 Nm Lambda sensor (Oxygen) : 30 Nm Chassis tightening torques Front hub :
  • Tighten nut in three stages:
    1. 130 Nm
    2. Slacken off
    3. 20 Nm + 80°-90°.
Steering track rod end : New nuts 60 Nm Brake disc to hub Front: 4 Nm Brake caliper to carrier Front: 30 Nm Brake caliper/carrier to hub Front: 95 Nm Brake caliper/carrier to hub Rear: 80 Nm New bolts ABS sensor Front: 8 Nm ABS sensor Rear: 15 Nm Road wheels : 110 Nm
There you go pretty much covers everything hope that helps
Jan 11, 2015 | Vauxhall Cars & Trucks
Toyota 5afe head bolts torque
Toyota 4A/ 5A-FE Cylinder Head Torque:
(a) Apply a light coat of engine oil on the threads and under the heads of the cylinder head bolts.
(b) Install the plate washer to each cylinder head bolt.
(c) Install and uniformly tighten the ten cylinder head bolts in several passes in the sequence.
Torque: 60 N-m (610 kgf-cm, 44 ft-lbf)
HINT: Cylinder head bolts are in length of 90 mm
(3.54 in.) and 108 mm (4.25 in.). Install the 90 mm
(3.54 in.) bolts (A) in intake manifold side positions.
Install the 108 mm (4.25 in.) bolts (B) in exhaust
Mar 31, 2014 | 2003 Toyota Corolla
Torque specifications
Head bolts are torqued in 3 steps, 1-18ft.lbs, 2-60 degrees, 3-60 degrees, camshaft caps-10-11 ftlbs, intake manifold-12-17ftlbs, exh manifolds-32-40 ftlbs, camshaft pulley-74-89 ftlbs.
Feb 05, 2014 | Cars & Trucks
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
Torque setting for a 1998 ford taurus 3.0 intake manifold
TORQUE SPECIFICATIONSDescriptionNmLb-FtLb-InEngine Air Cleaner Tube Clamps1.6-2.2-14-19Engine Control Sensor Wiring Through Bolts2.5-3.5-23-30Generator to Bracket Bolt3727-Generator to Cylinder Head Bolt4835-Generator Brace to Upper Intake Manifold Bolts and Nut12-209-14-Intake Manifold Support to Throttle Body8-12-71-106Intake Manifold Support to RH Cylinder Head40-5530-40-Degas Tube to Upper Intake Manifold Bolts8-12-71-106Camshaft Sprocket to Camshaft Bolt50-7037-51-Camshaft Thrust Plate Bolt10-88Coil and Bracket to Cylinder Head Bolt40-5530-40-Connecting Rod Nut31-3923-28-Crankshaft Damper to Crankshaft Bolt125-16593-121-Crankshaft Pulley to Damper (4 Bolts)40-6030-44-Cylinder Head Retaining Bolt(1)(1)-Accelerator Cable Shield Bolts1.4-13Camshaft Position Sensor Housing Retaining Bolt2417-EGR Tube Connector to Exhaust Manifold40-4730-34-EGR Valve to Upper Intake Manifold Bolt20-3015-22-EGR Tube to EGR Valve and Exhaust Manifold35-6526-47-Exhaust Manifold Bolt/Stud20-2515-18-Flywheel to Crankshaft Bolt73-8754-64-Fuel Injection Supply Manifold to Intake Manifold8-12-71-106Throttle Cable Bracket1713-Dual Converter Y Pipe to Exhaust Manifolds34-4725-34-Crankshaft Position Sensor Bolts5-7-45-61Intake Manifold to Cylinder Head Bolt (5)(2)(2)-Main Bearing Cap Bolt75-8556-62-Oil Drain Plug11-169-11-Oil Filter Insert to Cylinder Block27-4020-29-Oil Filter to Oil Filter Adapter(3)(3)-Oil Galley and Cooling Jacket Plugs2014-Oil Level Indicator Tube to Exhaust Manifold Nut16-2012-14-Engine to Transaxle/Torque Converter Assembly Bolts40-6030-44-Torque Converter Nuts27-4620-33-Transmission Range Sensor Nut16-2212-16-Front Sub-Frame-to-Body Bolts77-10357-75-Oil Pressure Sensor16-2212-16-Oil Pump to Cylinder Block Bolt40-5530-40-Power Steering Bracket to Cylinder Head Bolt40-5530-40-Valve Cover to Cylinder Head Bolts/Studs (5)10-14-89-123Right Exhaust Manifold Heat Shield Retaining Bolts8-12-71-106Rocker Arm Seat to Cylinder Head Bolt(4)(4)-Water Outlet Connection to Intake Manifold Bolt10-14-89-123Upper Intake Manifold to Lower Intake Manifold Bolt/Stud20-3015-22-Engine Front Cover to Cylinder Block Bolt (No. 1-10)2518-Engine Front Cover to Cylinder Block Bolt (No. 11-15)10-88Water Pump Pulley to Hub (4 Bolts)20-3015-22-Water Pump to Front Cover Bolt8-12-71-106Wiring Retainer Bracket Nut20-3015-22-Valve Tappet Guide Plate to Cylinder Block10-14-89-123Ignition Coil Bracket40-5530-40-Oil Pan to Cylinder Block Bolt10-14-89-123Water Bypass Tube Nut20-3015-22-Crankshaft Pulley Bolts40-5530-40-
  1. Tighten in four steps (refer to illustration in Cylinder Head Installation for tightening sequence):
    • Tighten in sequence to 70-90 Nm (52-66 Lb-Ft)
    • Then back off all bolts 360 degrees
    • Tighten in sequence to 45-55 Nm (34-40 Lb-Ft)
    • Tighten in sequence to 85-99 Nm (63-73 Lb-Ft)
  2. Tighten in two steps
    • 20-30 Nm (15-22 Lb-Ft)
    • 26-32 Nm (20-23 Lb-Ft)
  3. Advance 3/4 to 1 turn after gasket contacts sealing surface or tighten to 13-15 Nm (10-11 Lb-Ft).
  4. Tighten in two steps:
    • 7-15 Nm (6-11 Lb-Ft)
    • 26-38 Nm (20-28 Lb-Ft)
  5. Refer to illustration in the Cylinder Head Installation procedure for tightening sequence.
Jan 10, 2012 | 1998 Ford Taurus
Looking for head bolt troque spec for 3.4l impala sfi04
Please don't forget to rate. Thank you:
Left side front cylinder head
Cylinder head bolt torque sequence-3.4L engine
  • Cylinder head by aligning it with the dowel pins
  • New cylinder head bolts coated with a sealant (such as GM 1052080). Torque the bolts in the proper sequence (1-8) to 37 ft. lbs. (50 Nm). Using a torque angle meter turn the bolts 90 degrees in the proper sequence.
  • Left side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plugs. Torque the plugs 11 ft. lbs. (15 Nm).
  • Right side rear cylinder head:
  • New cylinder head gasket
  • Cylinder head on top of the gasket and make certain it is lined up properly with the dowel pins
  • Right side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
  • Spark plug wires
  • Exhaust crossover pipe. Torque the fastener to 18 ft. lbs. (25 Nm).
  • Valve rocker arms and pushrods. Torque the fastener to 89 inch lbs. (10 Nm). Using a torque angle meter torque the fastener an additional 30 degrees.
  • Lower intake manifold. Torque the bolts to 115 inch lbs. (13 Nm).
  • Upper intake manifold. Torque the bolts to 18 ft. lbs. (25 Nm).
  • Nov 26, 2010 | 2004 Chevrolet Impala
    Head gasket torque specifications and sequense
    Cylinder head bolt torque sequence—3.4L engine
  • Spark plug wires
  • Mar 06, 2010 | 2001 Chevrolet Venture
    How much lb ft. of torque should i put on the cylinder head bolts of a 1992 toyota hilux surf turbo diesel 2lt engine.
    what is the valve clearance and cylinder head torque for toyota 2lt diesel engine
    kasim
    Jan 25, 2010 | 1992 Toyota 4Runner
    Blown head gaskit need to remove head and replace with new ong
    2.2L (VIN 4) Engine
    1. Before servicing the vehicle, refer to the precautions section.
    2. Relieve the fuel system pressure.
    3. Drain the cooling system.
    4. Remove or disconnect the following:
      • Accessory drive belt
      • Air cleaner outlet duct
      • Engine mount
      • Intake manifold
      • Exhaust manifold
      • Engine Coolant Temperature (ECT) sensor electrical connector
      • Power steering pump
      • Radiator inlet pipe
      • Spark plug wires
      • Rocker arm cover
      NOTE Whenever valve train components are removed, keep them in order for installation purposes.
      • Rocker arms and pushrods
      • Lifters
      • Alternator rear brace and the alternator
      • Ignition coil assembly
      • Accessory bracket
      • Spark plug wires
      • Cylinder head bolts
      WARNING Two sizes of bolts are used; note the location of each.
      • Cylinder head
    5. Inspect the cylinder head and block surface for cracks, nicks, heavy scratches and flatness.
    Cylinder head torquing sequence—2.2L (VIN 4) engine
    1. Install or connect the following:
      • Cylinder head with a new gasket and new cylinder head bolts. Torque the long bolts, in sequence to 46 ft. lbs. (63 Nm) and the short bolts to 43 ft. lbs. (58 Nm) plus an additional 90 degree turn on all the bolts.
      • Lifters
      • Pushrods and rocker arms. Torque nuts to 22 ft. lbs. (30 Nm).
      • Rocker arm cover. Torque the bolts to 89 inch lbs. (10 Nm).
      • Spark plug wires
      • Accessory bracket
      • Power steering pump. Torque the bolts to 22 ft. lbs. (30 Nm).
      • ECT sensor electrical connector
      • Exhaust manifold. Torque the nuts to 118 inch lbs. (13 Nm).
      • Alternator. Torque the bolts to 37 ft. lbs. (50 Nm).
      • Intake manifold. Torque the bolts to 17 ft. lbs. (24 Nm).
      • Engine mount. Torque the bolts to 55 ft. lbs. (75 Nm).
      • Negative battery cable
    2. Refill and bleed the cooling system.
    3. Start the vehicle and inspect for leaks.
    Oct 08, 2009 | 2000 Chevrolet Cavalier
    What is the tension on cylinder head bolts for a jeep grand cherokee 307935 4 litre, 6 cylinder, 1999, petrol motor.
    Coat threads of left hand front bolt with sealant: 1st - step; - 22 ft./lbs. 2nd - step; - 45 ft./lbs. 3rd - step, all bolts except L.H. front bolt; - 110 ft./lbs. 4th - step, L.H. front bolt; - 100 ft./lbs. fig100.png
    Sep 05, 2009 | 1999 Jeep Grand Cherokee
    Air Tools & Compressors Logo
    Top Air Tools & Compressors Experts
    John Trevino
    JOHN LAPIER
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
