Question about Kitchen Appliances - Others
My machine does not kneed, I put all ingredient in the machine and it does nothing
Breadman ultimate bread won't rise
Ensure you are using the right ingredients, fresh yeast, a little salt and maybe a crushed vitC tablet. Don't use standard fine flour you need a courser flour. help it mix by putting ingredients in evenly, liquids first. melt any butter you use in a microwave before adding. most breads use artificially improved flours. if you grind your own flour it will end up a much heavier loaf.....i like it that way.
If nothing i have said helps then it might be time to give up on your breadmaker
Jan 11, 2013 | Breadman Tr2500bc Ultimate Plus 2-pound...
What order do i use for the ingredients for an admiral 4451303 bread machine?
In general, for all bread machines, add the wet ingredients, then the dry.
If you are going to use a timer feature, be sure the yeast doesn't get wet. A common solution is to put it on top of all the other dry ingredients. Panasonic/National machines have a separate yeast dispenser, but IMO there's no need...
Jan 08, 2011 | Kitchen Appliances - Others
I just received this for christmas and am trying my first bake. in the middle of the kneading process it started to beep over and over again .. is this suppose to happen
that is probably the beep for when you can add ingredients..some things get added after some kneeding ...ck the manual , it will probably explain
Dec 26, 2010 | Breadman Kitchen Appliances - Others
The breadmaker stoppes after kneeding ,nothing happens,no heat either the heating element will not even get warm?
There is a stage after kneading where the machine seems dormant and no or almost no heat is applied. This is the "Rise" stage. Do you have a copy of the manual that goes with your machine?
Oct 14, 2010 | Welbilt ABMIL2P Bread Maker
Need to know the order to place ingrediants into machineregal bread
Hi...Liquids and salt and sugar (if used) first. Next comes the flour....and finally your instant yeast sits on top of the flour. Salt will kill the yeast so if you use yeast that you mix with the water (proofing) then put the salt on top of the flour. Yeast and salt should be separated untill kneeding. Hank
Sep 23, 2010 | Regal Ware Kitchen Appliances - Others
Machine on but nothing happening
It could be two things that has happened. The easy fix is that the belt has fallen off the pulley and not turning the paddle or the belt itself is snapped. Secondly, it could be that the sealed bearing in the bottom of the bread pan is frozen. See if you can spin the paddle by hand. If no..then it's frozen. (try putting hot water in the pan to see if it frees up. If after a few tries it does not then the bread pan needs to be replaced). The motor and pulley assembly is located inside the base of the machine.
Feb 01, 2010 | Breadman TR850 Plus Bread Maker
How long do I cook the bread
Place the ingredients into the bread machine, liquid first, then flour and dry ingredients, make a little pit in the top of the flour and put the yeast in there. Then start the machine. You add fruit and nuts later, usually there is a beep for adding things.
Apr 10, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Ingredients order
I have misplaced/lost the manual to my machine and cannot remember the order of ingredients (for any recipes) to put into the machine. Can any one help me out with this? thank you in advance.
Jan 17, 2007 | Kenmore KTR2205SPR Bread Maker
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
