I lost the power cord to my "vintage fiber optic light" and would really like to use it. I don't know the voltage, so I can't even try to use another cord. Any ideas I what I can do?
Small tabletop vintage fiber optic light that changes colors and revolves (ufo 80's style light). We have some other power cords of different voltages, but am worried they might be too strong and blow out the light & probably not fit.
  • Office Equip... Master
  • 18,342 Answers
If it is the type that has a cord, a power transformer and then the unit, look on the area where the power cord plugs into the unit. It ought to have the voltage, milliamps needed and the polarity.
If you have only lost the power cord, it just need to same type of plug.
Posted on Dec 11, 2016
  • 1 more comment
  • ladebug62 Dec 11, 2016
    Actually, I had tried looking for any kind of markings as to the voltage, etc. There is nothing written on this thing at all. It was probably on the box or on the missing cord.
  • ladebug62 Dec 12, 2016
    Thank you anyway.
  • Andrew Taylor
    Andrew Taylor Dec 12, 2016
    You can get some power adapters with a switch that varies the voltage, usually, 1.5, 3, 5, 6, and 9 volts. Polarity won't matter, start at the lowest voltage and work up until the light is right.
What is the difference between Fiberglass spring and carbon fiber?
Both types are very similar. Even though the carbon fiber claimed to be lighter, stronger and springier, I can tell you that don't really feel the difference. Both are fine. The most expensive stilts on the market - The original power skip spring, still uses fiberglass.
Jul 09, 2012 | Sport & Outdoor - Others
While playing, the power cord was accidentally pulled out. When plugged back in, the amp cuts on, but there is no sound and the led lights for peak and tone selection flash.
You have probably blown a tube. This amp has one 12ax7 and one 12au7 in the vintage preamp. You can try replacing the preamp tubes, but it can be quite dangerous if you don't know what you're doing!
Sep 20, 2011 | Ampeg BA600-210 Bass Combo (with )
Installing a single mode backbone using 8.3um core and butting to a 9um core of existing fiber. will there be major losses and will existing laser equipment handle the 8.3 um fiber.
I ezpect there will be less attenuation with the laser Iight going from the smaller fiber to the larger fiber as all the light bundle will impinge within the radius of the larger fiber - on the other hand going the other way some light from the larger fiber to the smaller will be lost. I actually once had to match 9 micron fiber to 62.5 micron and found a company who could stretch the larger fiber down to the 9 micron giving me a light "funnel" which worked fine for the 800 foot distance I had to cover. Because lasers are powerful and the excess gain is high I expect you have a great chance of it working if your distances are not "miles". If you can get a hold of a laser emitter and receiver cable tester that would let you know your losses quickly. Reliable fiber communication with good cable is all about getting enough light thru to carry a signal. Perfection is not necessarily required as in my example.
Jun 29, 2011 | Corning / Siecor Unicam ST Single-Mode 8.3...
Pentair pool light fiber optic won't light:
check light generator on deck light probably burned out
Jun 14, 2011 | Pentair Pool & Spa
I have lost the power cord and would like to know the replacement price
you dot necesarily need to buy a replacement, these power cords are universal and you should be able to use any other power chord from even a completely different device. PLEASE NOTE THAT THE VOLTAGE OF THE POWER CHORD MUST MATCH THE VOLTAGE OF THE SPEAKERS
Oct 08, 2009 | Kinyo SW-7352 Computer Speakers
Lost power to printer after cleaning mirrors in optical box
Check the following.
Power switch on the back of mqchine ON.
Power cord firmly in place at both ends.
If there is a fuse or circuit breaker next to the power in connection, confirm it is good or reset.
All covers properly closed.
All internal units in correct position.
Hope this is of some help.
May 19, 2009 | HP Color LaserJet 2600n Printer
I want to know what PCM stands for
Either Pulse Code Modulation or Phase Change Memory, depending on the application, for a radio, most likely Pulse Code Modulation
Mar 24, 2009 | Audio Players & Recorders
Power problem
If you don't have any indicators working, you have probably lost your power supply. With no picture and no sound the chances are you have either lost the power supply or blown a fuse. If you remove the cover and look at the circuit board there is a fuse located near the rear of the chassis near where the power cord connects to the chassis. If the fuse is blown, it is advisable to replace your damaged power cord before replacing the fuse. The cord could have a short and this could create a fire. Be very careful when working on any television. Be sure it is unplugged for more than one day to allow the high voltage to decay from the picture tube. Do not touch the picture tube, it still may have some residual voltage and could shock you. If you replace the cord and fuse and still have the same problem, you will probably find that the high voltage transistor is bad and needs to be replaced.
Nov 07, 2008 | Philips 36PT842H 36" TV
Optical Cable input not working
It is likely that the optical fiber inside the cable is broken, it is really sensible and gets damaged easily. I'd try changing the cable before even opening the home theater.
Jan 13, 2008 | Samsung HT-WP38 System
