Question about Maytag Dryers
The dryer door model W10494218A is askew. How can I adjust to correct this?
The door on my Maxim dryer is slightly askew, making it rub on the bottom when I close it. It needs to be lifted a bit so it doesn't rub. How can it be adjusted?
  • 481 Answers
SOURCE: freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Posted on Jun 28, 2008
  • 1543 Answers
SOURCE: Doors need adjustment
You should be able to take the top trim caps off the door hinges, loosen the hinge screws a little, and move the door(s) away from the center of the refrig, then re-tighten the hinge screws to get the doors to stop hitting each other. You may want to check the bottom hinge(s) for the hight. The bottom hinges and the bottom of the doors have matching plastic "ramped" washers, which raise the door as it is opened, which help them to self close. If one of those is broken, the hight will be off.
Posted on Mar 14, 2009
  • 744 Answers
SOURCE: Kenmore Electric dryer Model 110.8708 - brand new,
Sounds like the door catch is weak. You can try to spead the prongs on the dryer catch (the metal protusion on the dryer, not the door), but be careful. Unless it's very easy to do, call the wrranty dealer for the the machine since it should still be under warranty and the catch should be replaced at no cost to you.
Posted on Apr 12, 2009
  • 121 Answers
SOURCE: Door is rubbing at the bottom of fridge. Can it be adjusted?
there is a kit that goes at the bottom hinge that will lift the door
Posted on Apr 17, 2009
  • 11 Answers
SOURCE: New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Posted on Aug 19, 2009
I have a meld wen vinyl slider that I am trying to install but I cannot remove the bottom metal track so I can install the window
You need to adjust the wheels up with the adjustment screws on the bottom end of the door. The door will lift slightly enough to let the wheels and door clear the track. So up and in. Then when replacing, lift up and set down on the track on the rollers and adjust up turning screw so that the door rolls easily without rubbing. Some doors adjustment screw is on the bottom door end, some are on the side of the bottom of the door a few inches back, depending on model.
Sep 03, 2016 | Cars & Trucks
LG wm2016cw smells when spinning fast. I opened the top but do not visually see any damage or smell it. When I open the door, I can smell something was rubbing. Took off the door gasket and it seems fine....
It sounds as though the drum may have dropped slightly and is rubbing against the seal. This normally occurs when either the top springs have stretched slightly (visually it's not noticeable) or the bearings are worn. Hopefully it's the former, as the springs are replaceable at little cost and can be done as a DIY project. The best way to see if it is the drum, is to close the door and look through the door window. The drum should appear central to the window. There will be online guides on how to change your particular model springs, as they are all slightly different. The only other possibility is that the drive belt at the rear of the machine is wearing out, or rubbing against something.
Dec 04, 2017 | Washing Machines
Belt Position on Drum of Kenmore Advantage Dryer 68738
Check to see if the motor is bound up.
What is the model number listed inside the door?
Nov 06, 2012 | Kenmore Dryers
1983 Yamaha XJ Maxim 750. Rear tire rubbing on driveshaft
Hi, Blzofaz for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
rear tire rub normal
How to remove the rear wheel of your shaft driven motorcycle
Yamaha XJ750 Owner Manual
OEM parts for Yamaha
May 25, 2010 | 1985 Yamaha XJ 700 S Maxim
Dryer door won't stay shut latch won't catch
If this specific dryer has the door that opens forward (top to bottom as opposed to left to right, etc...) the common problem is that downward pressure on the door has bent it slightly. This happened on mine when one of my daughters would lean on the door while loading and/or unloading the dryer. If this is the case, then the door may pop open while running even though the latch looks good.
The best way to tell is just let the door rest naturally in the closed position. If it does not rest all the way closed, then the lower portion of the door & frame has been slightly bent as indicated above.
The door & frame has to be slightly bent/forced back out at the bottom. This can be accomplished with a large screwdriver or something similar such as a paint mixing paddle or basically anything that will fit between the bottom of the door (from the inside) and the dryer frame. Very slowly close the door with the paint paddle or large screw driver in place (again on the inside...not from the outside of the door). The goal is to just barely force the bottom of the door framing back out without warping it grossly.
Just take your time and be as gentle as possible & make small adjustments until the door will remain closed and latched.
The latch is really only required to keep the door secure while clothes are beating against the door interior. Proper alignment actually keeps the door closed.
Let me know if this helps.
May 06, 2010 | Whirlpool LEN2000PW Dryer
My dryer is making a loud rubbing sound....the dryer shell is not moving funny or anything...and I smell do I check the belt in amana 1983 dryer
front glides and felt are bad and rubbing metal to metal. get model # go to and look it up. 2 screws on lower front removed (unplug dryer) pull bottom of front out and up till top clips let go be careful of door switch wires. label and disconnect them. check felt seal for damage. check glydes on towers holding drum up. it could also just be s coin or somthing stuck at drum edge.check the blower wheel make sure it's not stripped out or have somthing stuck in it.
Feb 17, 2010 | Amana Dryers
Door adjustment
Start by raising the front legs slightly to shift the directional pull of the door rearwards.
Feb 05, 2010 | KitchenAid KBFA25ER Bottom Freezer French...
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Refrigerator top freezer door slightly rubs to inside freezer bottom while closing the door that opens on right side. Due to this after closing the freezer door, the door opens less than a mm near the left...
I think I can help. Usuly the doors have been swapped around in this case. look closely at the freezer door on hinge side. there should be a small metal piece that covers the hinge to prevent anything from jamming hinge. this shield also serves as a spacer. this is what sets the door at the correct height. if the piece is missing you can have your local appliance dealer order one for you. it only takes a few minutes ts to install. you will need to remove the freezer door to do this. Hope this helps and good luck.
May 07, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Freezer door rubbing
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
