Question about Tablets & eReaders
I have a new emerson tablet, it turns on but the screen is an Android with a green line progressing from top to bottom, touch screen does not respond
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
krishdkiller
  • 384 Answers
SOURCE: when i try to turn on my android tablet the screen turns on but stays black then it shuts off
yes your os has got corrupted .
rush to service center .
they will re-format it. and it will be ok.
Posted on Jan 02, 2013
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
  • 22 Answers
SOURCE: have an android tablet but have lost an inside SD
Well their is plently of websites out their that you can download "flashes" like the software, http://www.redmondpie.com/download-and-install-android-2.3.6-gingerbread-grk39f-on-nexus-one-how-to-tutorial/ this is a good website for getting the software depending on what version of android you have and then tells you how to do it incase you dont know.
Thanks
Posted on Aug 06, 2013
jaretheil
  • 9 Answers
SOURCE: I have an android tablet, YouTube works but when I
If you updated your operating system you may need to go and turn the auto rotate back on under options.
Posted on Nov 04, 2013
I dropped it and although the screen isn't physically broken, it's not working properly.
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - Is your Android Touch Screen not working or being unresponsive? ...This will wipe your phone/tablet and return it to its original condition. ... a replacement for a glass broken? will I not reboot my phone and then it will work? .... My zenfone5 was dropped into water and some part of the screen isn't working.
iPhone Screen Not Responding - how to fix? - Tech-addict
www.the-tech-addict.com/iphone-touch-screen-not-working/
Nov 22, 2015 - Although the touch screen problem doesn't occur that easy, but still one can come ... Steps to fix if your iPhone Touch Screen not working properly ... to perform a factory reset i.e. restore your iPhone to its original factory settings. ... Touchscreen devices like iPhone, iPad, Tablets etc. are not only quite costly ...
Dropped phone, screen doesn't work. What repair kit do I need ...
forums.androidcentral.com > ... > Samsung Galaxy S3 > Sprint Galaxy S3
Sep 11, 2013 - When I try the unlock pattern on teh touch screen it does not work. ...the glass there does appear to be a spot that isn't the glass that is physically broken.... And I'm pretty sure once you get the phone disassembled, its just plug and ....Although I only had to do 1/3 of what was in them, they really are great for ...
How do I get my pictures off my phone if I have a broke screen ...
Mar 10, 2014
Brand new Galaxy S4 "broken" for no reason.
Aug 12, 2013
Does the digitizer break when screen is cracked on the Nexus 7 ...
Aug 3, 2013
TF700T now won't turn on.
Oct 15, 2012
More results from forums.androidcentral.com
Feb 03, 2016 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
My rca 7 voyager ll screen won't respond to my touch on one side of tablet what can I do to fix it
amazing-zone® for 7" Tablet PC Touch Screen Digitizer ...
www.amazon.com/...zone®-Tablet.../B00IRT4YCG
Amazon.com, Inc.
Rating: 4.2 - ‎93 reviews
For RCA voyager RCT6773W22 7" Tablet PC New Touch Screen Digitizer Glass Panel... Amazon.com will not accept returns of any desktop or notebook computer more ...for my nephews Emerson Tablet, although this one states it's for an RCA tablet, ... Itwon't respond to touch in about a half-inch band all the way across.
RCA Factory Reset & Reboot Unlock - YouTube
? 3:06
https://www.youtube.com/watch?v=ttvFDFqH5r0
Sep 19, 2014 - Uploaded by Rc Jr
Simple video on how to hard reset RCA Android Tablet. Unlock your ... Is the touch screen being un... ... If it doesn't reboot itself, try it again.. Read more Show less. Reply · 1 .... will this repeat all of my games ,pics and other stuff? ... I have one that won'ttype in certain letters on certain spots of the screen.
Jan 11, 2016 | Tablets & eReaders
Tablet is not responding ,to any comands
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
I have a Craig 7" Touch Screen CMP741e with Android. I have attempted many times to get it to reset to factory mode but with no progress. When I turn it on, it is stuck with the Android logo. I can no
You need to reload the firmware. There are two different versions of the CMP741e - the one you have is the newer one with the GT811 touch screen. You need http://www.craigelectronics.com/firmware_update/android4.0/cmp741e_firmware4.0_cleaner.rar for that model. Follow the instructions for the firmware update on the Craig website.
Mar 08, 2014 | Tablets & eReaders
One side of my nextbook 7 se is non responcive
Sorry, but this will require a new screen and a new digitizer. Might be cheaper to just buy a new one and put this on ebay to sell as parts/non working.
Nov 05, 2013 | Nextbook Premium 7 Capacitive Touch...
Ok I am having trouble with my Android Craig tablet. There's a message keeps popping up on my screen an it's blocking me from getting to my stuff. The message says "The application Launcher (process...
Phone is getting an error message: "Unfortunately Launcher Has Stopped."
Unfortunately Launcher Has Stopped:
  1. Swipe your finger from top to bottom on the screen to view the notification panel
  2. Touch the Settings or
  3. Touch Apps
  4. Touch Menu or
  5. Touch Reset App Preferences
  6. Touch Reset Apps
  7. Swipe from right to left 2-3 times to show the ALL list.
    (For device running on Android 6.0.X touch Menu then Show system)
  8. Touch Launcher
    (For device running on Android 6.0.X touch Stock Android then Storage)
  9. Touch Clear Data
  10. Touch OK
  11. Power Cycle Phone
  12. Test phone
hope this isn't clear as mud. :) and helps you
Jan 05, 2018 | Craig Electronics Wireless 10" Color...
Emerson tablet
Hold the power button down for about 8 seconds to force it off. Hold it till screen goes dark. Don't release if "power Off" dialogue pops up. Keep holding it to force off.
Apr 16, 2013 | Tablets & eReaders
Emerson tablet touch screen is frozen. How do I get it to work?
There is a tiny reset hole on the back of the tablet marked with a "R" near the SD card slot. Push a small paper clip in the hole until you feel it hit the button. This will reset the tablet and the touch screen will start working again once you power it back up. --Emerson m744 android tablet.
Dec 04, 2012 | Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
