Hardware & Accessories Logo
B
Beulah Wilson Posted on Dec 11, 2016
Utilitech instruction on model #0144506 - Hardware & Accessories
I need the English instructions for the Utilitech timer #0144506
I found a Utilitech timer at Lowes with the item number #0144506. The Utilitech model number for this timer is UTTNID001. If this is the correct timer, the manual is on the product page: https://www.lowes.com/pd/Utilitech-15-Amp-1-Outlet-Digital-Residential-Plug-in-Lighting-Timer/4740850 . Scroll down and expand the Guides & Documents section. The direct link is currently: http://pdf.lowes.com/useandcareguides/054732817825_use.pdf .
I hope this helps.
1helpful
Utilitech pump model KLHO75 manual
Lowe's has the manual for the Utilitech KLH075 0.75 HP submersible pump on the product site: http://www.lowes.com/pd_240035-84862-KLH075_0__?productId=3880627 . Click on the Info & Guides tab. The direct link to the guide is http://pdf.lowes.com/installationguides/717301122392_install.pdf . This is labeled an installation manual. The operating instructions start on page 6.
I hope this helps.
Mar 24, 2016 • Plumbing
The utilitech 0144506 I have won't charge when plugged in. No display comes on.
Troubleshoot if timers do not work:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Buy another timer at Lowes and take defect back in new package.
Try plugging into different outlet.
Press reset button to restore functionality.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
2answers
I lost my instructions for my Utilitech #0357930 timer. I cannot get it to work; I can set it to start but not stop. Just need some directions. Buttons on it are On, Off, Day, Hour, Min, Enter, Pro
The AutoChron 81000 Programmable Wall Light Switch Timer is identical to the Utilitec #0357930 (AmerTac) TMDW50L. Here are links to manuals for models prior to and as of 2012.
Before 2012
As of 2012
How do you set a utilitech timer
Which Utilitec timer do you have?
Following page has instructions for 0192773, with links to 0155671, 0144506, and 014124 programmable timers:
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Add a comment with your timer ID and I will help more.
If your timer is not shown on link above, add a comment and describe your timer.
I have extensive files on timers.
2helpful
2answers
How to program utilitech 1 outlet daily timer
Do you have the Utilitec number?
Add a comment with description of timer I can help.
I own several Utilitec timers.
Following link shows programming for 4 different Utilitec timers;
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
1helpful
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Top Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
