TV shows a large x. No sound - Televison & Video
I have a laptop with sound and I connect a large screen to it, but the large screen does not have speakers.
Get a set of remote usb speakers. Is it a large monitor or large screen tv? If it is a tv it will have speakers. They will work if you have an HDMI CONNECTION on your laptop.
Sep 19, 2017 | Apple Computers & Internet
Seiki TV no picture or sound
hi test the large diodes on the power board these can stop the led from firing up, thanks, ps send me a picture of the power board i'll show you the diodes
shaun
Jun 15, 2017 | Seiki Televison & Video
My 32inch LCD tv screen goes black and no video shows while the sound evrythingf else works. what could be wrong? am i looking at a large cost to repair? cheers Aa
Now,tv turn on u have a picture few sec.than dies have sound left only?Yes,than those 2 tv long boards call the LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Jan 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have sound but no picture screen is black 19inch screen
I cannot say enough about this model. There is a bad capacitor or two in this set. You should be looking for a buldged cap at maybe 25 or 35 volts at 2200Mfs. Replace this and the next one near would be a 35 volt at 1200 Mfs. I have a question for you, if the model number is 42 MF, the screen is large. And yet you say it has a 19 inch screen. I'm not sure if you have the large TV or the small TV. The answer I give you is for the large screen. Hope this helps you! Thanks for asking and show a few hands of support!
Oct 07, 2010 | Philips Magnavox 42MF521D/37 Television
Tried to use 2002 Sony TV as large monitor for webinar. Got the TV to accept signal but could never size the screen correctly. It only showed part of the computer image. Gave up on using it as large...
Symptom shows that it is convergence out chips failure that causing misaligned images on screen. Please replace convergence out chips in tv to get converge picture.
Question shows it is Sony KP-46WT500, if it is different model let me know please.
I can provide you more technical assistance if you wish to repair tv by yourself.
Thanks.
Feb 09, 2010 | Sony KP-46WT500 46" Rear Projection...
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
Buzzing sound coming from TV
Sounds like a power supply, could be a large capacitor or a large transformer making the noise
Mar 14, 2007 | Harsper HP-4200VPM Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
