Question about Dryers
What's screen to sign on to check my sercise years?
I WANT TO SIGN I[P FOR NET FLIX
depends on number of screens you view at same time
1=95.88 for a year
2=119.88 for a year
4=143.88 for a year
Oct 21, 2015 | Computers & Internet
Benq FP737s - Not working suddenly - Black screen
Most like just burned out and needs repaired or replaced.
Nov 11, 2007 | BenQ FP737S-D 17" LCD Monitor
Pogo games sign in sousaevelyn3@aol.com
Go to the following link below, but instead of signing in, choose the "Forgot password or screen name" link below the Screen Name and Password boxes.
Sign in to get access to Pogo
Different websites and companies processes are different, but they will typically send a reset link via email.
Just follow the directions and you should be back to playing games in no time!
Aug 27, 2014 | Computers & Internet
I have a acer 4740g laptop.I ve got display problem.It shows several lines and i cnt work on it.Recently it got little pressed on its display.Can any1 help me?
Hello shreejan_man
First thing to do is to test the screen. Also you have not mentioned if there is any cracks or damages.
Plug the laptop to an external monitor (any type will do). If the display on the external monitor is OK then it means the laptop screen is damaged.
If the display on the external screen is the same as the laptop then the problem is internal with the graphic chip or the video contacts.
this laptop is not that old since acer released this model last year. Check you warranty status on it. Some acer laptops come with two year warranty. Check the laptop carefully, if there is no sign of physical damage, (cracks, chips ...) then take it back as a warranty issue.
Good luck
please leave comment, vote if this helped.
Feb 24, 2011 | Acer Computers & Internet
I just got an alcatel OT-800A phone and i tried to set up a lock code and when i tried it locked me out and said i needed a PUK code
just call the customer sercise.... tell them the phone type and the problem.. after that they will ask for ur name, social. and thats it.. after that they will give u 8numbers (do write it down and label it) also ask for the puk2 code and do the same write down and label it... these numbers will not change unless u change phones and sim card
Feb 12, 2010 | Alcatel One Touch C750 Cellular Phone
PS 80130183
You need to sign up for the Playstation Network. Its free and you can sign up on your PS3 or on the computer. I will provide you links on how to do both.
Tutorial-Sign up on PS3
Link for Signing Up on Computer
Also, check and make sure you have the latest Firmware Update for your PS3, you can check that by going to the Settings Tab on the XMD main screen and go up to the "Check for Updates".
Thank you and have a wonderful day!
Don't forget to rate the overall satisfaction of this solution.
Jun 05, 2009 | Sony PlayStation® 3 (60 GB) Console
Wont heat
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 25, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Need to get parts for byD:sign lcd m#D:4242m
I bought 40 byd:sign 23" LCD screens from them about 1 year ago and installed them in a hospital enviorment. The sets are starting to fail. Do you have an address or phone number for them? I would be greatful for any help.
Respectfully
John Liljeblad
Amerisat, Inc.
858-505-1122
Jun 21, 2008 | byD sign d:4222 42 in. EDTV-Ready Plasma...
MISTUBISHI VS-50501A - top 3/4 of screen displays ok, rest does not
Check the vertcle yoke pins for solder cracks. Check verticle output circuitry resistors and transistors. And also check for Coolant leaks from the CRTs this happens alot. Check capacitors for any signs of sweeling or heat as well.
Sep 15, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Dryers Logo
26 people viewed this question
Top Dryers Experts
