TV turns on then a large x is displayed. What does that mean
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
TV SOUND NO PITCHER
connect the TV to a DVD player, if there is still no picture then it means the fault is from the Y-Sustain board of your TV.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hoping this will help in solving the problem....
Regards.
Nov 10, 2011 | Televison & Video
I can hear the sound but can't see the picture
The Problem is in either power supply or the Y-Sustain board.
Take care in solving the problem......
May 15, 2011 | LG Televison & Video
If i turned ON , sometimes , tv screen and image does not appear but sound is on ! That problem appear not all the time i used TV and if i turned off and on a few times - that inconvenience is dissapear...
Check for dry soldering, bulged capacitor, but if otherwise Problem is in either power supply or the Y-Sustain board.
Thanks and take care...
Sep 02, 2010 | Toshiba 32A3000 32A3000 32 16:9 Multi...
Tv turns on but no picture but has sound and menu
55" rca projection tv turns on has sound but no picture
Feb 11, 2010 | RCA Televison & Video
TV displays RGB code and then displays, no signal and then shuts off. What does the RGB code mean?
It means the source is not set correctly. Switch the source to input 0 (cable or antenna depending on your particular set up).
http://www.vizio.com/l32hdtv10a.html#support
Will lead you to the manual and quick start information if you need more specific instruction.
Joe
Jan 03, 2010 | Vizio L32 32 in. LCD HDTV
My phone shows a large E in the display next to the battery display, what is this for?
The large E means the 2.5G (GPRS) network is connected. please refer to the Nokia 7510 manual
Nov 18, 2009 | Nokia 7510 Cell Phone
We have a large screen TV and it displays a solid
your closed caption system is turned onn to its TEXT FUNCTION use your remote to find the CC or closed caption option and turn it off and the block will go away . good luck
Oct 26, 2009 | JVC Televison & Video
Black Box on Screen
that can be TXT i mean teletext button can be activated and you should turn off your TXT by pussyng Tv button on your remonte control
Jun 20, 2008 | Sanyo AVM-2556 25" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
