Question about Tower Dryers
Does the tropical breeze tower heat room too?
Why does mitsubishi split system heats room 5 degrees hotter than setpoint on remote
It could be something as simple as 'solar gain' adding heat through glass facing the afternoon sun....or maybe the remote is not in a location that senses the average temperture within the room. Maybe the remote is located in a slight draft entering the room.
If the remote was kept above a computer tower, the opposite would be the case.... the heat from the tower would keep the control thinking its warmer in the room than it is. The result would be a much colder room.
Mar 10, 2015 | Mitsubishi MUZ-FE09NA-1 MSZ-FE09NA-8 Mr....
Why do salt water aquariums need heating and cooling units?
Most saltwater aquariums are generally used to housetropical fish. Tropical fish are fromthe Tropics (the area of the planet around the equator.) The water temperature varies in differentlatitudes and depths, but it tends to stay between 77-80F (about25-27C). Therefore, you want to houseyour fish in the environment that is most like the one they are accustomed to,if you want them to stay healthy. Therefore, maintaining aquarium temperature with heating and coolingunits is essential.
May 13, 2012 | Fish
Our fan keeps turning off in the middle of the night and then immediately back on. This process will repeat all night until you turn it off.
The fan might be set to something called "night mode" (which I have no idea why it's called that because it just keeps me awake). Try changing the mode that the fan is set to. Or, refer to the owners manual.
Jun 21, 2011 | Tower Tropical Breeze Nexus Fan
Fan will not stay rotating,
The rotation lever was be disalligned just retightend.
Jun 19, 2011 | Tower Tropical Breeze Nexus Fan
Aloha breeze tower fan can it be a heater too?
The one I have can. Pushing the comfort control button will cycle from cool, to low heat, and then to high heat and then back to cool.
Sep 15, 2010 | Heating & Cooling
TV turns off on its own, have to keep turning it back on. This goes on and on about every 5 to 10 minutes.
We have placed a fan on TV and it has solved the problem. I guess it was over heating but for no obvious reason, other than we live in the tropics with no A/C in that room but lots of ventilation.
Jun 08, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Can a refrigerator be placed in a garage that houses the electric furnace?
Hi, all fridge freezers work on ambient room temperatures, ie room temperature. Also it will depend on the classification of your fridge freezer. On a normal classification fr/free 70 degrees should be a constant maximum. On a sub normal classification room temp should not exceed 50 degrees. on a sub tropical room temp can be pretty much as warm as you like. On the rating plate inside your fridge freezer two small letters exist (N) normal. (SN) sub normal. (ST) sub tropical. Most fridges will work for a while in the wrong temp but will work too hard and pack up
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I am listing one on EBAY today.
search for Aloha Breeze Ceiling Fan/ FAN REMOTE CONTROL
It should be listed in an hour or so. Kindiskandi42 is our ID on EBAY
Jun 04, 2008 | Tower Aloha Breeze Fan
How do I run the tower fan?
Plug it in...push the power botton. If you don't know which that is, hit them all until you feel a cool breeze.
Aug 30, 2007 | Tower Aloha Breeze Fan
Dryers Logo
Top Tower Dryers Experts
Jay Finke
Jay Finke
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Tower Dryer Expert? Answer questions, earn points and help others
