I have a confort zone/red stone space heater model cz530 and the alarm came on underneath the thermostat word what does that mean
4 Suggested Answers
SOURCE: Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
Posted on Dec 06, 2008
  • 3 Answers
SOURCE: Lakewood space heater thermostat source
If it is a Ksd31 thermostat you need, you are in luck. I found what I needed for my model 5600/7 on ebay. The store Larksining sells the for as few as five/pkg in various temp. settings. I got 5 ea. in two temp settings for less than $11.00 USD with shipping from Hong Kong.
Posted on Jan 26, 2010
gluedtke2
  • 151 Answers
SOURCE: I have a Comfort Zone heater model no. CZ550, the
Take it back to the store , sounds like the thermal fuse burned out . a factory defect that you need to send it in , on a warranty factory defect . Don't take it apart or you will void the warranty in most cases . Good Luck !!!!!!!!!
Posted on Nov 15, 2014
Adt home alarm system zone 3 red light is blinking
Sounds like you might have an old A910 panel from ADT. I could be wrong on this because I'm not sure what the panel type is but if it is an A910 panel (3 panic buttons on the bottom, vertical zone list with lights next to each zone) the red light means the zone is open and/or in alarm. It could be caused by a number of different things. Look for missing contact/magnets on the doors/windows that have alarms, often times they get loose and come off. Hope that helps!
Feb 02, 2014 | Home Security
My confort zone infered heater comes on for a few minutes then shuts down
Does it shut off heater with lights and fan on or power off? Did you bypass the temp sensor or thermostat? If temp sensor that mounts above filter, see http://www.fixya.com/support/t15119324-comfort_zone_cz2011_heater_shuts_off .
Feb 14, 2013 | Comfort Zone CZ1500WC Infra-Red...
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
Need to change my comfort zone heater from Cent. to farenhight
I can't say for sure but many circut boards or thermostat boards will have what is called a dip switch on the board it self. this is a small I mean tiny switch. Often you will have a set of them together so their easy to find. You will need a small awl or knife poilt to switch it as it is that small. It should be marked on the board so you can find it. Also on some if you simpley hold the temp button for fivr or ten seconds this will switch it for you but I think yours will have the dip switch. Good luck.
Dec 18, 2009 | Comfort Zone NEW 09 Electric Portable...
Wiring for a Honeywell RTH2310B
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Jan 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Nov 08, 2007 | Comfort Zone CZ-530 Compact Heater
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
