On a refrigerator front-load dryer ad shows up in the little space where the time is to be late
5 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Frigidaire front load dryer
If its under the 1 year manufacturers warranty ,use it!
Posted on Jun 02, 2008
SOURCE: LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
Posted on Jul 16, 2009
SOURCE: iDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Posted on Oct 05, 2011
kachbibi1
  • 979 Answers
SOURCE: Frigidaire Affinity Front Loading Electric Dryer. In about 5 minutes of starting the dryer, an error "Ad" shows in the window above the start button. Then the dryer stops and the lights under the "Ad"
I believe that code means auto dry. Lets make sure the lint and dust is clear from the machine. Check all of your wiring out well since is generally a cause. You may ave to replace the thermistor. Have you gotten any other code along with this.
Posted on Mar 04, 2013
Testimonial: "Thank you Bill Dickerson, I have found my manual now for error codes and how to read them and am now getting E56 on digital display read out. But not showing that error code on the manual???"
Why was my ac frigid today but not 2 hrs later
There is a possibility that the refrigerant level is getting low. The best way to determine this is to locate the receiver dryer under the hood of the vehicle. With the A/C running at medium to high, you should touch the top and bottom of the receiver dryer and both sides should be cold. If there is an uneven cold, the level of refrigerant is probably going down. Remember that refrigerant is lost not only through leaks, but through condensation especially in very hot weather. That is the reason why you see the puddles of water when a vehicle moves from a parking space that has had the air conditioner on for reasonable period of time. In any case, it is good practice to have the system checked about every 5 years to ensure that you have sufficient oil in the compressor. Refrigerant is loaded into a port that is on a hose that goes to the receiver dryer. Never consider the high pressure side that goes to the condensor that is found in front of the of the radiator. Doing so can result in injury. The charging port is usually marked with a black or blue cap. Make sure that you load only R-134 into the system. Good Luck
Aug 05, 2014 | Vehicle Parts & Accessories
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Mar 04, 2013 | Frigidaire AEQ7000ES Dryer
Ge profile 7.5 dryer front loading how to vent on the right (gas)
You should be able to vent in any direction.U might have to buy right part.
Oct 02, 2009 | GE Dryers
Grinding noise from the drum motor
My brand new one is doing it only after 1 week. I'm also interested in it. I'm thinking of pulling it apart and watching it and trying to find out where it's coming from exactly.
Jul 19, 2009 | LG WM-3677HW Front Load Washer / Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Jun 27, 2009 | Frigidaire Electric Dryer
Dryer shuts off, no heat, AD code
During normal operation, the display may show: “ad” - dryer is in an auto dry cycle. “dn” - cycle is done in auto dry. “PF” - a power failure to the board has occurred. “Err” - an error has been detected. “LOC” - control lock is activated. “PAU” - cycle has been interrupted.
Jun 18, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire GLEQ2152ESO Dryer flashing AD
AD means "auto dry", which means the dryer is supposed to be detecting the moisture levels in your clothing and adjusting the drying time accordingly.
If your dryer is flashing "AD" and turning off shortly after the start, there is likely a problem with the mechanism designed to detecting the moisture levels. If it turns off after trying to use all various settings (including the no-heat feature), it is likely a wiring issue.
Mar 27, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Front Load Washer and dryer
Yes I  find them all the time on the 2nd floor so you should be ok. Proper loading makes these machines very smooth. Sort out towels together, casuals together, socks and whites together.
Oct 19, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
