Tips on getting my flat screen tv will not turn on how do I get trouble shooting tips
mewms_14904
  • 1027 Answers
SOURCE: GATEWAY 7330GZ PC NOTEBOOK
This link will provide you the required information.
Specifications
Part Number: 4997Gateway 7330GZ Notebook
System Gateway® 7330GZ Notebook Processor Mobile Intel® Pentium® 4 Processor 532 with HT Technology
(1MB L2 Cache | 3.06GHz | 533MHz FSB) Determine Your Processor Speed
Chipset Intel® 852GME Screen 15.4-inch Widescreen Ultrabright TFT WXGA
  • Maximum Resolution: 1280 × 800
  • Maximum Color Depth: 32-bit (16.7 million colors)
  • LCD maximum refresh rate: 60 Hz
Memory 512 MB DDR (1 × 512 MB), 333 MHz, DDR
Expandable to 1.5 GB Video Intel® Extreme 2 Graphics
Dynamic Video Memory Technology (DVMT) supports up to 64 MB shared video memory Audio PC2001 Compliant AC '97 Audio
Built-in Stereo Speakers Hard drive 80 GB HDD (4200 RPM) Optical drive DVD +/- RW Multi-Format
  • Write maximum: 8X DVD +/-R, 4x DVD +/- RW, 24x DVD+R DL, 24X CD-R and 10X CD-RW disks
  • Reads maximum: 8X DVD-ROM Disks, 8X DL/+RW, 24X CD-ROM disks
Media reader 6-in-1 Digital Media Manager
Compact Flash, Micro Drive, MultimediaCard (MMC), Secure Digital (SD), Memory Stick, and Memory Stick Pro Modem 56K ITU V.92 ready Fax/Modem Network 802.11g integrated wireless (up to 54Mbps)
10/100Mbps integrated Ethernet LAN Pointing device Touchpad with Vertical Scroll Zone PCMCIA 1 - Type I or Type II; Card Bus Interfaces
  • 4 - USB 2.0 Ports
  • 1 - VGA External Connector
  • 1 - IEEE 1394 port
  • 1 - RJ11
  • 1 - RJ45
  • Microphone In
  • Headphone/Audio Out
Battery 8-cell Lithium-ion Dimensions 1.6-inches H × 14.0-inches W × 10.4-inches D Weight 7.5 pounds (8.65 pounds total travel weight)
Posted on Mar 24, 2008
SOURCE: Vicking VIDV500 Kitchen Hood
I have a 36" V600 wall mount hood. Replaced both bulbs and they still won't light. Fan works perfectly. Unit has on and off switch and dimmer switch. Any suggestions?
Thak you, Mike
Posted on Dec 01, 2008
SOURCE: symbol barcode scanner, handheld, cordless, yellow
error code communication error the scanner is not communicating with the cradle. It is important that the synapse cable is plugged into the cradle before the cradle power suply is pluged into a outlet. also could be the scanner did not pair up with the cradle correctly try rescanning the barcode on the cradle.
Posted on Jan 27, 2009
  • 119 Answers
SOURCE: The driver side window of our Nissan Quest Van
1st need check fuses for windows next check switch capability by switching up and down see if window will respond next check power to switch next check power to window motor if all ok replace window motor don't forget to check window rail make sure not jaming
Posted on Jan 18, 2010
SOURCE: need a manuel for 24v
out put not comming
Posted on Dec 27, 2010
I'm having trouble with my Samsung LED tv I am getting audio but no video. I See a blue screen then eventually gets darker. Any ideas what the problem may be?
Hi Will,
This is common problem with many samsung LED TVs. This is related to the back lights in the LCD panel. If you ask Samsung they will advise for the panel replacement. If you can find someone who is expert at handling this kind of sets, the panel can be repaired also. Good luck.
Mar 23, 2015 | Samsung UN60EH6050 60 LED-LCD 1080p HDTV
I have a Mitsubishi HD1080. There is a blue band through the screen when were watching tv. What are some trouble shooting tips that can help?
To help here or suggest a answer I need the model number which will begin usually with VS,WS, or WD--located on rear of set on a label.
Apr 02, 2012 | Mitsubishi Televison & Video
Look like shadow and it is to much color
I have not repaired a plasma TV. As I understand, the plasma TV has a picture tube similar to those in older TVs. I have read about them, and have an authorization for two other TV manufacturers. The bulletins I have read described trouble shooting problems. Your TV may be exhibiting a blue or red hazing problem. This is most certainly describing a bad plasma screen. This problem is a common occurrence. Once again I have read many trouble shooting tips regarding this problem. Under warranty we are asked to replace the screens. If this TV is not under warranty, the cost will exceed the price of a new TV. Sorry, about your TV. You may opt for a second opinion, and please do so. Thanks for asking and show all hands of support!
Jul 29, 2011 | Daewoo DSP4210GM 42 in. Plasma Television
When i first turn my tv on it shows colored lines when i first turn it on then when it warms up it goes away.
it means there is a problem inside of your TV unit.if you have an idea about trouble shooting like this i can give you some possible tips for you to look. first is check possible loose contact in your chassis board cold soldered parts. check also leak capacitor at video section and at vertical section. if you don't have an idea how to be done all this you may need to look for a qualified service technician.
Apr 09, 2011 | Televison & Video
Trouble shooting every six second always turn off him self
This is cause by your inverter. When they go bad you will either have a dim screen or intermittent screen flashes. You will need to call the manufacturer for a replacement and the installation is actually not that difficult.
Refer to my article detailing how this is done in my Tips section.
http://www.fixya.com/support/r4489343-flat_panel_television_repair_yourself
Aug 05, 2010 | Akira Televison & Video
My element turns on and the gas will light ocasionally.
If the igniter is glowing and even sometimes lights the burner, it's not the igniter that's bad. I've created a checklist that most homeowner's can use to trouble shoot dryer lighting problems. Click on my username, scroll down my profile to my tips and tricks for trouble shooting gas dryers.
Hopefully, one of these tips will solve your problem. Good luck.
May 18, 2010 | Amana NDG2330AW Gas Dryer
Screen blinks when tv warms up
First this set has a way to get the error codes, you can search threads here or go to ctechnicians.com
Dec 30, 2007 | Mitsubishi WS-48313 48" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
