Question about The Watches
How do you set up weide WH-2309 LED time (not the analog time)
Weide wh1103 watch.hands stopped working.function buttons work ok.battery powered.hands move when turning winder button.
The Weide watches use springs for their electrical connectivity and I've found that they don't work very well. I had the same problem and after tinkering with all of the connections I came to the conclusion that they were built to not have the battery replaced.
Nov 01, 2017 | Watches
Weide wh1103 watch hands stopped working.other functions still ok.
1. did you check the battery? some analog-digital watches have two batteries. one for analog and the other for digital.
if so, try to replace one of the battery.
2. maybe your watch need to clean the internal mechanism. bring it to service center.
How do i set the day ? Mine is stuck on sun.
I would try removing the battery for 10 minutes reinstall the battery if it doesn't help there's a problem with the circuitry.
Hope it helps thank you.
Jun 10, 2015 | Novelty 30M Waterproof Analog & Digital...
How to set analog time for casio SGW 400 h please help
Analog time follows the digital time on Casio watches.If this is not happening,try the hands "set to 0" procedure using the manual.
Mar 31, 2013 | Casio Watches
To adjust the analog time for ga-110hc-1a
Analog time follows digital time.Correctly set your local time and analog time will come up correctly as well.If not, try to run the hands alignment procedure (H-SET) following manual instructions.
Mar 02, 2013 | Casio G-Shock GW500A-1V Wrist Watch
I am looking for instruction manual for Weide sports watch WH902
Does exist a function to beep hour a hour in model Weide WH2309?
free-shipping-watch-fashion-weide-sports-watches-wh-2309-with-quartz-led-watch-for-watches-men-aq2i4dbsyqjd0wgvev1j31bb-4-0.jpg
Nov 10, 2011 | Watches
I have a casio ediface 5033 80W-M10008 how do I set the analog time
Thank you for contacting FixYa.
To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
Best regards. Jewel
Sep 15, 2010 | Casio Edifice EFA109-7AV Wrist Watch
How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
Setting Digital Time
  1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
    Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
    Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
    After the time is set, press the upper left button to exit the digital time setting function.
  2. Setting Analog Time
  3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Aug 21, 2010 | Casio Watches
Cannot set the analog time on the Casio 2747.
In timekeeping mode press bottom left button 6x to enter setting mode.
Then hold down top left button until digital time flashes, which indicates your in analog time setting mode. press bottom right button to set the time.
If you hold down bottom right, it will set time at a faster speed.
Hope this helps
May 25, 2009 | Casio AW80-7AV Wrist Watch
I cant set analogue time on casio hd wrist
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Mar 30, 2009 | Casio WVA430A-1AV Wrist Watch
Watches Logo
Top The Watches Experts
John mullen
D. E. Hev
 En Sukkert
En Sukkert
Level 1 Expert
Are you a The Watch Expert? Answer questions, earn points and help others
