Question about Apple iPad Mini
I cannot get back on my ipad mini. donot remember password or ID..they have in the past asked me to change it and it never works. now I don't have a clue
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
You will need to factory reset it. You will lose all data and pictures, but it is probably the only way to access it. I do not think Apple will help you if you do not know your ID and Password. If you knew at least your Apple ID they might would help you out with password.
Posted on Dec 12, 2016
Apple ID and password help. My deceased husband set up the password and ID and I am locked out of my IPad. It asked for the original
Try hooking your iPad up to iTunes on your computer and perform a factory reset, changing the username and password.
Jun 05, 2017 | Apple Tablets & eReaders
Re set ipad mini
Generally speaking, you need the Apple ID to reset your iPad. iPad needs you to enter the Apple ID to switch off your account and the Find My iPhone service will be turn off. If you are using iTunes to reset your iPad, you need to enter the Apple ID when your iPad reboots.
But if you have no Apple ID or passcode, you will have to reset your iPad without Apple ID. To reset iPad without Apple ID, you need first put iPad into DFU mode and connect it to your iTunes. Your iTunes will help you to reset your iPad without entering Apple ID easily. Resetting your iPad with this method will result in wiping all the data in your iPad. The following steps will show you how to do that.
Step 1: Open iTunes on your computer and connect your iPad to the computer with a USB cable.
Step 2: After that, turn off you device. Press and hold the Home button for 3 seconds.
Step 3: Put your iPad into DFU mode: Press and hold the Power and Home button for 10 seconds. Then release the power button and keep holding the home button. When you see the Apple logo disappears, you have successfully put your iPad into DFU mode.
Step 4: When iTunes detects that your iPad is in recovery mode, you can restore it now.
Step 5: Click on Restore iPad. Then you will be notified after the reset and your iPad will take a restart.
After resetting your iPad with the guidance mentioned above, you'd better create a new Apple ID and password in time. After resetting iPad, you will get all the data swept from iPad, and you can restore the files from your iPad, iTunes backup or iCloud backup. However, you can't backup iPad to iTunes/iCloud without Apple ID before you reset your iPad. In this case, you need the third-party iOS data recovery software to help you recover lost data from iPad after factory reset without Apple ID.
http://www.leawo.org/tutorial/how-to-reset-iphone-without-apple-id.html
Jan 01, 2017 | Apple Tablets & eReaders
I need help resetting password on my mini ipad. My ipad is has asked for this
hello,
Thank you for posting question. what problem exactly you are facing.
please describe in detail. is your ipad working or is it stuck on some error.
Nov 12, 2016 | Apple iPad Mini
How to factory rest ipad mini with out using the apple I'd or password
Connect it to a computer with iTunes. Set up your own Apple ID and Password. Then Reset the iPad.
You can also do it from the iPad itself Settings - General and at the very bottom command RESET.
After the reset you will be able to set it up from new.
Please note that the RESET command clears EVERYTHING off the device.
May 08, 2016 | Apple iPad Mini
Trying to password for e mail, one time correct and then told us something else was incorrect have tried resetting it no results.
If your password to yahoo, or any other email service was correct, they may be asking for your Apple id and password. The Apple ID and password were the ID and password you used to set up the tablet.
Mar 18, 2015 | Apple iPad Mini
On my apple ipad mini model A1432 that I bought from a friend the passcode that I'm putting in is incorrect. How can I get a new passcode?
After you put in the wrong pass code 3 times, you only can unlock the iPad with the correct password, belonging to the Apple ID from what is only a part shown on the screen. If you don't have the passcode nor the password Apple assumes you are not the legal owner, and you can't use the iPad anymore. Just go back to your friend, ask him to unlock the screen, to wipe the content and reset the iPad to factory settings.
For that goto settings, general and scroll to the bottom line and press that. then the second line wipe everything. Again the login code is asked. but after that the iPad is empty.Your friend should also remove the iPad from his list of registered Apple equipment.
Jun 17, 2014 | Tablets & eReaders
Just bought an ipad mini i have a netgear router the ipad is asking for a password where do i find this?
Did you set up a password for the router? If you did not, then check on the user manual what default password the router has. Usually its 1234 or 12345678 or even a lot of numbers. Consider the back or bottom part of the router device. Sometimes manufacturers put the default passwords there.
Feb 02, 2013 | Apple iPad Mini
Open Questions:
See all Apple iPad Mini Questions
Apple iPad Mini Logo
543 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
