Question about Panasonic Microwave Ovens
How can I replace the fuse in a Panasonic NN-A774 oven?
    President:
  • Panasonic Master
  • 1,922 Answers
Unplug unit first!!!!dangerous voltages inside up to 2000 volts at cap terms, remove outer cover and fuse should be on top or near corner and side of unit/you need a special fuse available at most hardware stores and radio-shack stocks them,they're called a "Ceramic Fuse"
Posted on Jul 27, 2009
  • jrn63 Aug 29, 2011
    Cannot locate the fuse, even after taking the control pad off and removing the top. Diagrams?
How to replace fuse
The external enclosure has to be removed to gain access to the fuse but be aware that you will be exposed to dangerous, even fatal, voltages even with power removed.
Jun 16, 2016 | Panasonic NN-SD277WR - NN-SD277WR...
Where is the fuse on Panasonic NN-S252
You may have to remove the cover on the microwave to find a fuse. It may not be either in a fuse holder or soldered into a the circuit board. be sure it is not plug up when you check.
if you find it be sure and replace with the fuse with same current rating.
Aug 01, 2014 | Panasonic NN-S252WF Microwave Oven
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Microwave fuse keeps blowing on my Panasonic Microwave NN-9854P
I would check the door interlock switches and then if that doesn't fix it replace the invertor board and possibly magnetron.
Feb 21, 2011 | Panasonic NN-P295SF Microwave Oven
Where is the second fuse in my panasonic nn-s963bf the one for the heating and what does it look like?
There is no second fuse. Look for a thermal cutoff there are a few of those. Test it for open circuit and replace.
Aug 11, 2010 | Panasonic NN-S963BF Microwave Oven
Panasonic NN-C980B stopped working. Blown fuse.
Sometimes when the mag shorts it takes out the inverter. I would measure the mag leads to ground and they should be open or 20M or so. If you have both a mag and inverter bad it's probably time for a new oven.
Apr 19, 2010 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
My Panasonic nn-s262 fan and light not working. All other functions are operational. Is there a fuse in the microwave that needs replacement?
Hello, you will need to take the cover off the microwave and look for a fuse internally which should be mounted onto a pcb or electronic board.
NOTE: Be very careful if the microwave is stainless steel as they are very sharp.
Jun 18, 2009 | Panasonic NN-S262SF Microwave Oven
Microwave Ovens Logo
157 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
