How remove f 16. And what the mean of f 16? - Office Equipment & Supplies
  • kakima Dec 11, 2016
    Hi Sahil , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model calculator?
How can I find the mean absolute deviation?
Mean absolute deviation.
Let's break it down into its components.
Mean - Average
Absolute - absolute value - sign doesn't matter - if negative, make positive
Deviation - difference from the mean
Let's do an example. Population 3 7 4 2. Total 16. Mean (Average) 16/4 = 4.
Deviations
3 - 4 = -1 absolute value 1
7 - 4 = 3
4 - 4 = 0
2 - 4 = -2 absolute value 2
Sum of these deviations 1 + 3 + 0 + 2 = 6
Mean (average) of these deviations is 6 / 4 = 1.5.
Good luck,
Paul
Apr 05, 2016 | Texas Instruments TI-30Xa Scientific...
How DO I operate the beam saw
Not sure what you mean. It has a safety button on it that you press before you can pull the trigger. Is that what you mean?
Oct 21, 2014 | Makita 5402NA 16-5/16" Beam Cutter...
How to calculate mean
The mean is (1+5+9)/3 = 5.
The squared deviations are (1-5)^2=16, (5-5)^2=0, and (9-5)^2=16.
The sum of the squared deviations are 16+16 = 32.
Divided by one less than the number of data points, 32/(3-1) = 16.
The square root of 16 is 4. This is the sample standard deviation.
Apr 25, 2014 | Office Equipment & Supplies
How to remove a mazda 626 samp
Do you mean the sump. If so remove the engine.
Apr 17, 2014 | Mazda 626 Cars & Trucks
16-5x2-2=20
Assuming the first '2' means "squared" then the equation is already correct for certain values of 'x'.
Apr 05, 2013 | Mathsoft Computers & Internet
I want to know the total sq foot of a 16'x14' room the total of a 14'x5' and a total of a13'x13' room Or the total of all 3 together. Thanks
If you have a calculator just turn it on and typ[ what follows.
[X] means you press the multiplication key
[=] means you press the = key
[+] means you press the addition key (plus)
16 [x]14 [=] area of first room.in square feet
14[X]5[=] area of second room.in square feet
13[X] 13= area of third room in square feet
If you want to obtain the total area of all the rooms at one go
16 [x]14 [+] 14[X]5 [+]13[X]13 [=]
Aug 25, 2011 | Office Equipment & Supplies
Hi i have a nokia 16 16 cell phone i want to use the sim card that i have been using for about five years but when i insert it in to the 16 16 the monitor diplays SIM NOT VALID what can i do? the IMEI no ...
Dear,
Your phone is locked to a specific Network so that you can not use any other SIM apart from that network.
You need to unlock your phone, so that it can accept SIM from all network.
Phone repairing shops will unlock it for you for $5-$10 Aprox.
You can also search internet for unlock codes.
Hope that will help you to unlock your phone
May 10, 2011 | Nokia 1616 Cell Phone
My PIU Cube 16 Olimpia Splendid portable air conditioner is displaying an error message f1, can anyone solve what this means? Thanks
It means 'Dirty Filter' once cleaned you must press and hold down the 'On' button for 5 seconds and the message will remove.
Feb 24, 2011 | Heating & Cooling
Getting error code 16. what does it mean and what
a 16 error code is typically caused by scale formation. I'd recommend performing a descale on the heater.
Mar 06, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
How can i remove clothing stuck in my kenmore elite oasis?
if it is up under the agitator just remove the agitator,,,,pop the cap off with a screwdriver then remove the 7/16 bolt and lift out whole assy!
Feb 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
k24674
jasbo
jasbo
