Question about Home
My motion sensing exterior wall mount LED lantern won't turn on
3 Suggested Answers
SOURCE: I have an exterior copper lantern with broken
Contact a glass company, but also look for a stained-glass maker.
Stained glass is set inside a soldered frame. That person will have the tools to fix it.
You will probably have to get a handy-man to remove the outdoor lamp so it can be taken to the glass shop.
Posted on Oct 30, 2010
SOURCE: size of wall mount for GPX LED HDTV
looking for the whole mount that mounts to the tv and then to the wall
Posted on Sep 28, 2015
How do i mount my sansui lcd at wall
Go to or amazon .com
Jul 04, 2016 | Sansui 24" 720p 60Hz LED HDTV SLED2490 in...
This type of unit does not drain into the outside unit. It drains into a nearby interior drain, or just to the outside near Inside unit. If the unit is cooling properly, you're ok.
Jul 01, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
Hi- I have a Nexxtech LED Lantern that is no longer turning on.
Have you checked that the batteries are seated properly?
Sep 15, 2017 | Camping, Backpacking & Hiking
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Swissgear rechargable lantern won't light up, even though the green led light indicates it is fully charged
There are several different models of the Swiss Gear rechargeable lantern. On most though, you can remove the top portion of the lantern and check the lighting element inside. In most cases the elements can be removed and replaced. I have a dual filament lantern and from experience I know that every so often you may have to go buy a replacement light piece. If the lantern has been bumped or even just strapped to the outside of the pack while walking, it's possible for those elements to become loose and need repositioning or replacement so do check that. I'm sure that it should be unlikely your charger is malfunctioning unless you left it plugged in for some very extended period of time, in which case I would say the light would be more likely to burn out. But definitely try that and if that doesn't work the battery pack on the lantern itself may have an issue in which case you can always get a replacement.
Aug 29, 2012 | Camping, Backpacking & Hiking
Installation instructions for a Cooper Wiring Devices OS310U-W-K Motion-Activated Occupancy Sensor Wall Switch, White
LED bulbs with leaking motion sensors tend to flicker as well, more so than CFL. I switched to Cooper style - but now my Cooper OS310u will sense motion - and keep sensing motion almost all the time. If it's in test mode - it will shut off but otherwise it keeps sensing it. This is in a garage - and door open or closed does not seem to affect it. I have the same unit working in my basement just fine.
suggestion - don't try LEDs to solve the problem and yes - it will burn out your CFLs real fast.
Jan 12, 2012 | Electrical Supplies
Garage door only opens sometimes with remotes< and exterior keypad. always works with wall mount button.
Check the light bulbs in the opener. Newer fluorescent or LED bulbs can generate enough radio frequency interference that the normal signal levels from the remote will be inadequate.
Of course, make sure the remote batteries are fresh.
Sep 04, 2011 | liftmaster Garage Door 1/2 Hp
Looking for a wall motion switch that has a 180 degree side view
Try the GE Motion sensing switch found at Wal-Mart on the electrical asile. I believe it is made by JASCO Products. I use this is my garage and closets without an problems.
Dec 29, 2010 | Heath Zenith SL-6106-IV Motion Sensing...
How can I disconnect the motion detector on the Chamberlain 3/4 HPS Whisper Drive Plus Belt Drive Garage Door Opener with EverCharge
There is a button on the side of the wall-mounted remote. It has a pic of light bulb next to it. Press it once - the motion sensor is on and the lights will be on once it senses the motion; press it again and the motion sensor will be off.
Jul 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Motion sensing
still need help have not seen a solution or am not sure where to find it?
After installing my lantern the sensor dosen't pick up when crossing it's path but comes on when coming from opposit corner meaning head on which people comming up to the door wouldn't triger it Thank you in advance Hampton lighting model HB 4190series
Jul 21, 2008 | Electrical Supplies
Home Logo
29 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
