Question about Compaq Evo Notebook N610c
ABCDEFIJKLMNOPQRSTUVXWXYZ REST OF KEYS DO NOT
LLLABCDEFIJKLMNOPQRSTUVXWXYZ REST OF KEYS DO NOT WORK I CAN NOT USE MY BACK SPACE
    Scholar:
  • 85 Answers
Hi
can you plug in an external keyboard via PS2/usb port? try this and see if it works, If so you could try taking your internal keyboard apart and cleaning the key contacts, usually a bit tricky/fiddely but would save you the cost of a new keyboard, disassembly instructions for your keyboard should be found on the 'net or a new replacement keyboard, Hope this helps.
Posted on Jul 20, 2009
How to fix digital scale reading LLL
LLL probably indicates "Off-Level".Take batteries out / unplug power,re-apply power and make sure scale is Level....LLL also might indicate power is Low....make and model # ???
May 09, 2017 | Health & Beauty
Tip
GET THE MOST OUT OF YOUR BRAKES!!!!!!
Get the most out of your brakes, be sure to leave enough space at least 3-4 car lengths between you and the car ahead of you allowing you to stop without panicing and slamming on the brakes, causing excessive heat build up etc.(don't tailgate drive).
Also try to replace your old brake shoes/pads with a better quality, don't just look at price, cheaper means less metallic and quicker wear of the pads than the better ones.
Make certain you dont have any brake calipers that have sticky pistons causing the pads to rub excessively on the rotors, not allowing the pads to come back to there rest position.(retract)
Be certain you don't have leaking calipers/wheel cylinders as well and check the brake hoses for cracks, breaks, leaks, replace those that do.
When replacing the disc pads be sure to use all new brake hardware to keep the pads and calipers in good working order.
Use the proper brake fluid the new cars are being called out for today, generally type lll or lV.
Happy Motoring!!!
on Aug 10, 2010 | Acura Integra Cars & Trucks
I need to replace the utensal tray for the whirlpool quiet partner lll. Where can I order one? Thx
Try typing onto the space bar on your computer either " Whirlpool parts" or Sears parts". Follow the instructions, and be sure to have your model number handy. Be blessed.
Feb 09, 2013 | Dishwashers
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
http://www.laptopkey.com/installation_guides.php
Oct 10, 2009 | Dell 0Y3740 Keyboard
I have a lincoln mk lll won't start when key is on
That should be easy for you. Ign sw,safety sw,ballast resistor if you have one,bad ground at coil. How about starter solenoid wires on wrong terminals. Did the old starter work as wired now!! How about a schematic to make this go away quicker. Iam a 60's guy also like the mk111 . Wife has a 2004 LS
Sep 26, 2009 | 1981 Lincoln Continental
Acer 4520 keyboard problem
The only problem that keyboard can have is when there is too much dust in the hollowed part of it it makes the keys to be wrongly spelt and if by mistakenly you relax on it or something resting on it when loading up your Post On Self Test then it can be seeing what is not even type on it with this information you can easily know what have happen to it then if there is nothing then your keyboard need a replacement.
ok
bye rate this solution
Oct 07, 2008 | Acer TravelMate 2300 Notebook
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Compaq Evo Notebook N610c Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
