Question about Woods Hardware & Accessories
I bought a Woods mechanic timer from Menards. After the first 24 hour(one cycle), it will not work as a timer, because it's always on. How can I set it as a timer?
    Top Expert:
  • Woods Master
  • 40,418 Answers
Surely, the timer must have come with instructions
Posted on Dec 11, 2016
Need help programing lllwoods model 50000 indoor 24 hour mechanicl timer 2-c
Copy following link to identify timer and download possible manual:
If you have the digital timer, generally you can toggle DST back-and-forth 1 hour by pushing two buttons simultaneously for 3 seconds. And then reverse the setting again by pressing and holding both buttons again.
Open link. Download manual. Look for 'daylight savings time' in manual. Read instructions.
You can unplug timer to make programming changes, since the timer has a carryover feature against power outage.
To restore functionality of a timer that no longer works, press reset button and then reprogram.
The Woods 50000 series are new line of timer introduced just before Christmas 2012.
Woods timers are warranted by Coleman/ Carol Cable/ Canadian tire, and I suspect the timer itself is made by Intermatic.
All these timers have standard 1 year limited warranty against workmanship defects.
I have not seen any complaints about this line of timers here at fixya.
Add comment if you need more help.
Apr 18, 2013 | Woods 2C 24 Hour Indoor Mechanical Timer...
I need a night light timer that I can set to be on for 50 minutes and off for 10 minutes and repeat this every hour for 24 hours.
1) If you have programmable timer, then it would require 24 ON and 24 OFF settings, with down-to-the minute programming.
1 ON for each hour.
1 OFF for each hour.
Following link shows Grasslin 50-60 Hz 230Volt din rail timer with 50 memory slots. 16 amp at 230 volts
2) If you have 24 hour mechanical timer with dial, it would need 24 ON trippers and 24 off trippers with down-to-the minute schedule.
No timer has that capability.
3) There is C8800 series cycle timer. 120-240Volt 60Hz for US market. 20 amp at 120volts, or 20 amp at 240Volt. Chose 1 hour cycle, then insert 100 trippers and leave 20 blank spaces.
4) There are percentage cycle timers.
For example CT2000. Rated 120Volts 60 Hz for US market.
Select 1 hour cycle, and 16% or 84% percentage to choose ON or OFF
Nov 28, 2012 | Woods Indoor 24 Hour Night Light Timer...
How do I set a Woods indoor light timer model# 16ULD/3AO? I can't figure it out!! Kathy
Timer not identified for certain:
Open following links to see how to set analog timers by experimenting with features, and identify different timers:
Add a comment any time for more help.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
Woods timer 49646
Woods 49646 timer appears to be 24-hour analog timer.
Open following link to identify timer:
Open following link for instructions how to set and use analog timers:
Open following link if information above does not match your timer, and you want to identify different timer:
Sep 02, 2011 | Hardware & Accessories
I'm using the woods 59200 mechanical timer to automatically open and close a chicken coop door. I can't for the life of me figure out how to set it. Help!
Woods 59202 is 7-day analog VACATION timer and cannot be set.
Vacation timers are preset to turn on-and-off at random times so it looks like somebody is home when you are away.
You might want the 59201 analog timer which can be set for on-off times over 24-hour period. Minimum on-off is 15 minutes.
If you need a 7-day timer, buy a programmable instead of analog. Wooods 59377 or Intermatic DT630 heavy duty
If you have analog plug-in timer, open following link to see how to set timers:
Jul 05, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I have a Woods 59336 time which was given to me without instructions. How do I set it.
Open following link to identify timer and download manual
Instructions are same as 49522 shown below the 59366
You posted next to photo that looks like 59201 timer:
Open following link to identify that timer and download manual
Add a comment if you need help with specific part of instructions, and add your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Mar 29, 2011 | Woods 3C 24 Hour Indoor Mechanical Timer...
Have GE digital timer 15117. Can't figure out how to make the display show AM/PM so I can set it correctly. Clock hour/min just cycles through 12 hours without noting AM or PM setting. Can't program...
GE 15117 manual
You might try a new AA battery.
Some guy wrote in this week and said he bought 6 timers and all the batteries were bad except 1.
Some timers, like Woods TD1300, and others have the 12 hour or 24 hour option.
You press and hold Time button to choose 12 hour or 24 hour
But GE 15117 manual says nothing about this option.
GE 15117 timer is same timer as Woods 59403
Several folks have written in past couple weeks about the Woods 59403 timer skipping over functions.
The best I can guess is your timer is malfunctioning like the other people's timers.
Woods 59403 manual is identical to GE manual, and says nothing about 12 hour 24 hour option either
I test timers for programming and wiring difficulties.
Yesterday 3 timers arrived here, and 1 didn't work.
I took it apart and tested the electronics, and something went bad.
When these timers don't work, you get your money back or throw them away.
Dec 04, 2010 | GE Hardware & Accessories
How do i program the 24 hour timer by woods?
You posted under Woods indoor plug-in 24-hour mechanical timer.
This particular timer:
Rotate dial until current time lines up with words: 'time now' located on inner dial
To set on-off times, look carefully at dial that rotates.
There are tiny pins that stick up on the dial.
Each pin represents 1/2 hour.
Use fingernail and click pin outward for each half hour you want timer ON
Leave pins inward for each half hour you want timer OFF
Next, plug table lamp into side of timer.
Last step, plug timer into wall outlet.
If this is not your timer, see all Woods timers and manuals:
Or add a comment and I will help.
Nov 17, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
Hardware & Accessories Logo
48 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
