Manual typewriter. types only half the lower case letters
MediaMan85
  • 163 Answers
SOURCE: Only typing half letters and numbers
On the WheelWriter series, sometimes the platen may pop out of position, causing only half the letters to print. If this is the case, easially solved... Using the left and right platen knobs, firmly push down to lock it back in place. Hope this helps....MediaMan
Posted on Jun 08, 2007
  • 3594 Answers
SOURCE: lower case c
Sounds like it needs a new printwheel.
DickyO
Posted on Jul 11, 2008
  • 3594 Answers
SOURCE: darker striking characters & lighter striking one, carriage will not move forward when typing the letter "L" lower case.
Try Code "L" this will take you out of the Language Mode.
DickyO
Posted on May 11, 2009
  • 3594 Answers
SOURCE: Typing half letters
If it was working befor you changed the ribbon check to be sure the ribbon's feet are engaged in the slots on the ribbon deck, that the blue latch is latched and there isn't a fold in the ribbon. If all of these are OK push down firmly on both ends of the platen.
DickyO
Posted on Feb 16, 2010
  • 3594 Answers
SOURCE: The bottom half of letters are not typing. I just
First be sure the platen is fully seated and locked in the side frames, Then be surethe ribbon is on allthe way, then try it without the L/O tape.
DickyO
Posted on Jul 16, 2010
Typewriter is only typing the top half of each letter- changed ribbon- still doesn't type the bottom of the letters ???
typing the top half of each letter Donna, sounds like the carriage spool is stuck or out of adjustment. Not to hard, but pick up typewriter and slam it down on counter to see if it put carriage and spool back in position.
Good luck.
Mar 31, 2016 | IBM Wheelwriter 30 Series II Typewriter
How do I adjust character print to the vertical center of the platen? I'm getting only the top half of my elite type images.
I was a typewriter tech 4 10 years, exactly what brand, model, electric manual. Does it change when you shift From upper case to lower case Jhonny 5 needs more in put.
Mar 08, 2015 | Office Equipment & Supplies
My smith corona sl 570 is not printing the letters c,v, b and n in both lower case and upper case. how can i fix this?
You have a key board problem. It may just need disassembly and cleaning but more likely it needs a new contact velum.
DickyO
Jan 03, 2014 | Smith Corona Wordsmith 100 Typewriter
Why does my typewriter only type the top half of the under-case letters?
There is most likely something interfearing with the type bar segment try ing to lift up, try pulling it up by hand.
DICKYO
Jun 17, 2013 | Royal Office Equipment & Supplies
Et personal 540 sp wont type capital e
If your typewriter types using a print WHEEL the Cap S is probably broken off. Replace the print wheel
Apr 24, 2013 | Olivetti Office Equipment & Supplies
Typing only half letters
Possibly the lower edge of the ribbon has become folded over during fitting, it happens.
Apr 19, 2010 | Smith Corona Wordsmith 200 Typewriter
Lower case c
DickyO
Jun 24, 2008 | Brother Office Equipment & Supplies
Jun 06, 2007 | Lexmark Wheelwriter 1500 Typewriter
jasbo
jasbo
