Question about Samsung Televison & Video
I changed the DLP chip on my 67" Samsung TV. When I finished with the installation, the picture is blurred. I can't even read the screen.
tvrepairbiz
  • 63 Answers
SOURCE: vertical black lines on my 50" Samsung DLP TV
You need to replace the digital board
Posted on Sep 03, 2009
  • 304 Answers
SOURCE: signs that the bulb in a dlp is going out
A DLP Lamp will fail in two ways. 1.The glass tube housing the filament will shatter and the TV will not turn on. 2. The lamp has many hours of use on it and will gradually grow dimmer. At no time will the lamp cause any picture defect. Check your Cable or Sat box for the correct aspect ratio as well as the TV aspect ratio. Chances are the aspect ratio in either system is set incorrectly. If the gray borders are uniform then the aspect ratio is not set properly. If this occurs on certain channels but not others then the particular channel is broadcasting in the 4:3 aspect ratio and there is nothing wrong with your set.
Posted on Apr 14, 2010
  • 171 Answers
SOURCE: DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
Posted on Aug 20, 2010
  • 8457 Answers
SOURCE: I have the Toshiba 65hm167 DLP, It has a bunch of
Yes,this problems is the Light projection Engine.The chip is bad.This happen to many models of tvs in the industries.Sony,Samsung,Mishibishi and Toshiba they all use the same IC chip.Call Toshiba make kind of deal with them,help u replaced the chip or the Light Engine it self.This problems is not new many people went to You Tube **** about this problems.
Posted on Sep 03, 2010
ripleymojica
  • 643 Answers
SOURCE: I have a 67" DLP TV and last night 2 white spots
That usually indicates that the optical block is going bad. That repair is usually 900-1100 dollar fix.
Posted on Mar 30, 2011
I replaced the DLP chip in Samsung 67in TV. Now when i turn on TV the entire screen is a huge blur. It also seems to have 5-6 big water spot looking areas.What do i need to look at to fix this?
There is nothing you have to look at to fix this. What did you think? Replacing a DLP chip and to make adjustments to it is very like to eat a banana?
Contact any well experienced service technician or leave it away for ever. http://electronicshelponline.blogspot.com/
Oct 11, 2016 | Samsung Televison & Video
I had pin holes on my projection tv, with the hlp of jimmys .com video I was able to change out the dlp chip, tv looks great except picture is1in to high on the screen. Samsung HL67A750A1FXZA . HELP
A Convergence of the screen problem made by a special tool made on marketing technical decision in a little memorychip or (maybe there is a special servicemode for picture geometrical adjustments , ask for it your dealer or it has autoconvergent then there could be are also a few bad capacitors to replace. most change to find in the vertical group.
Samsung HL67A750A1FXZA Service Manual Page 19
Sep 03, 2016 | Samsung Televison & Video
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
My 67" samsung tv work well when its on but when you turn off tv and turn back on you get sound and no picture unplug tv and plug in again picture come back on
First thing I would try is to remove set and a box or receiver if used from power for a while and then plug all back up--should reboot all units that way--cannot hurt and may very well help. Not just the set but any unit between signal source and set.
It might also be a good idea to see if when the screen is black if the lamp can be seen--is it on or not?
Dec 12, 2012 | Samsung HL-67A510 67" DLP HDTV
What is the solution to the white dots in the samsung tv screen?
Replace the optical engine. See my tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine for help with getting a new one and installation.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 07, 2011 | Samsung HL-67A510 67" DLP HDTV
Mar 30, 2011 | Samsung HL-67A510 67" DLP HDTV
Signs that the bulb in a dlp is going out
Apr 12, 2010 | Samsung HL-67A510 67" DLP HDTV
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
DLP With White pixels scattered all over the screen some fliker some don't
The DMD chip has gone bad. Check to see if you are still in warranty. Samsung has a one year parts and labor warranty on your set. If your set is out of warranty then ONLY the DMD Chip needs to be replaced. DMD part# is 4719-001997
Jul 10, 2009 | Samsung HL-67A510 67" DLP HDTV
Numerous white spots on Smasung DLP TV
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
May 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
