Question about Sewing Machines
My needle keeps falling out. I unscrewed the set screw, put the new needle in, then it falls out. I had just taken out an old needle by unscrewing the set screw and didn't touch anything else. Help
  • Sewing Machines Master
  • 11,522 Answers
Be sure to unscrew the set-screw and extra turn and then insure you are pushing the needle all the way up before tightening it. Could also mean the set screw is stripped...
Posted on Dec 12, 2016
How to change needle
Depends on your sewing machine. There is a screw that holds the needle in place. Unscrew it (don't let the needle fall into the bottom of the machine!). Pay attention to where the flat side of the needle is positioned in the needle holder! Then just insert a new needle with the flat side facing the same direction, push the needle up as far as it will go and tighten the screw.
Jun 20, 2017 | Sewing Machines
How do I change a needle on my husqvana 905 overlocker
Each needle has a small set screw holding it in place. Just above the needle from the front you can loosen the needle by using a T6 (Tork 6) screw driver (if you don't have the original tool that came with the serger) to loosen the needle. Before loosing the screw, I would put a piece of fabric or paper over the needle plate to catch the needle (or part) to keep it from falling in the machine. Turn the screw counter clockwise (to the left) to loosen. Insert the new needle and tighten. It's not necessary to remove the screw entirely, just loosen it and the needle usually just falls out.
Good luck.
Jul 05, 2014 | Husqvarna Sewing Machines
I can't figure out how to replace the needle on a Juki MO-3314E industrial serger
There should be a lever (probably black) at the back left side of the machine. When you push down on it (strongly) it should release the whole foot to swing out left from the machine. I think that model has its needle holding screws on the front and you will probably need a small allen wrench / needle wrench to unscrew that small needle screw. I could be wrong. Sometimes they are just a regular needle screw that is unscrewed with a small screw driver.
Unscrew the needle screw and take the old needle out. Try not to drop it into the machine because this can start a whole new set of problems. You can use tweezers or needle nose pliers if it is hard to hold on to it. I think that this model takes a B-64 needle and probably either a 12,14,16,18 size. Use the size that was already in it if you know. If you don't know, you may be able to read it on the top of the old needle (you may need a magnifying glass if it is pretty worn).
Put your new needle into the hole where the old one came out, making sure that the 'eye' of the needle is straight forward or it will not make good stitches. You may already know this, but just in case you don't, the front of the needle is the side that has a groove straight down the front of the needle to the hole so that the thread can run down it to the eye as you sew. If you put the needle in backwards, it will probably not make stitches.
Make sure that the needle is as far up into the hole as it can go and tighten your needle screw. Thread your needle (s) and lay the thread ends towards the back of your machine. Now, make sure that the threads from the loopers are coming directly from the eyes of the loopers, not tangled up with each other and lay those thread ends towards the back of the machine.
Turn the handwheel on the right side of your machine forward until the needles are as high as they are going to go.
Now, push down on the black lever on the back of the machine and swing your foot back into place. Before you try to run it, make sure that the foot is 'locked' in place. You can assure yourself of this, by trying to wiggle the foot from left to right. It should not move from left to right when locked into place. Now turn your handwheel forward again slightly to make sure that your needles are not going to hit the foot. If all is well, run a small piece of fabric through the machine and check the stitch.
Good Luck.
Jun 26, 2014 | Juki 6716 Mechanical Sewing Machine
How do I keep the walking foot from unscrewing the needle holder on my bernina record 730
Tighten your needle with a screwdriver, instead of finger tight. If that continues to happen, take your walking foot back. That is not normal, and could end up injuring you or damaging your machine. Good luck!
May 24, 2014 | Sewing Machines
I need to replace the needle
There is a thumb screw by the needle. Just unscrew it enough to be able to remove the needle by pulling straight down. You may need a small screw driver. HOWEVER, when you take the needle out, by pulling it down, notice where the FLAT SIDE IS It may face backwards or forwards, but it is important that the new needle is inserted this same way. Push the new needle up into the opening where the old needle came out, making sure it is pushed all the way up. You may need to unscrew the thumb screw a bit more to facilitate insertion. Jiggle the needle while pushing it up into the opening to be quite sure it is seated properly. Then, hold the needle with one hand and tighten the thumb screw with the other. Using a small screw driver, (one should have come with the machine), tighten the thumb screw all the way down. No need to over tighten, just make sure it is really snug. Piece of cake:) Good luck. She may have broken it, but he needs to read the manual:)
Apr 06, 2013 | Singer Zig Zag 727198 Sewing Machine
I have a white superlock 534- I recently broke a needle and now I cannot load two needles. After unscrewing the screw- I try to load two needles and only the right will stay in--left falling out. If I load...
I have a White Superlock 534,the needle broke and I tried to change the needle and lost the screw,it is so tiny I cant find it,is their any way I can buy the same tiny screw.I like to have 2 needles.
May 29, 2011 | White Sewing Superlock 1934D Mechanical...
I have a Nelco sewing machine and i forgot how to put in a new needle thanks!
There should be a screw down by the needle, by the presser foot. Unscrew that button and remove the old needle. To replace that with a new one... there put the top of the needle into the needle hole. There will be a flat side to the needle and a rounded side. The flat side goes in the back. Once you have the needle in its position, tighten the screw to hold it in place. Let me know how it goes and if that fixes it.
Oct 09, 2010 | Sewing Machines
Change the lightbulb
should be one screw on the back side of the machine top right if facing the back, remove that and you can get the side cover in front of the needle bar off, you should have easy access to the light
Jun 02, 2009 | Brother XL-2230 Mechanical Sewing Machine
Needle keeps falling out of Pfaff Creativ 2170
change ur needle bar and also check needle size before insert in it.
Sep 14, 2008 | PfaFF Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
